Over active regen - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rutcutter, this thread has received 18 replies and been viewed 1550 times.
post #1 of 19 (permalink) Old 06-19-2007, 03:56 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Over active regen
My truck has been regening every 100 or so miles,I took it in friday for the flash and thought that would cure the problem,today the truck started regen after only 20 miles since the last regen :shrug: Had to go in the lumber yard and turned the truck off and when I restarted the truck didnt go into regen again..
Anyone else have this over active regen happen to there 6.4L?
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #2 of 19 (permalink) Old 06-19-2007, 04:24 PM
I noticed when I drive in rush hour or city driving for long periods of time it regens more often- like every 150 miles.
Rainman is offline
post #3 of 19 (permalink) Old 06-19-2007, 04:47 PM
the computer does a regen cycle when the pressure sensor in the dpf reads high enough. extended idling, bad or wrong fuel can cause excessive regens.
bowtiehatr is offline
post #4 of 19 (permalink) Old 06-19-2007, 05:06 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Yea I drive alot of city stop and go but that seems like ALOT of regens to me.
I buy all my fuel from a big shell station and have never gotten any bad fuel from there but I guess it could happen.
2011 SD F350 6.7L
post #5 of 19 (permalink) Old 06-19-2007, 06:19 PM
Learning to smoke
I don't know what that means? some one tell me so I can understand this better
FATSO is offline
post #6 of 19 (permalink) Old 06-19-2007, 06:21 PM
I also fill up at shell often, don't think fuel is a issue. I think it might have something to do with the stop and go driving, how hot it has been lately, and running the A/C alot.
Rainman is offline
post #7 of 19 (permalink) Old 06-19-2007, 06:41 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Well its been in the mid-upper 90's here and the AC is always on.
2011 SD F350 6.7L
post #8 of 19 (permalink) Old 06-19-2007, 06:46 PM
yea its because of the city driving, everytime you take off the truck creates a lot of black smoke which then clogs the filter. After driving in 6.4lKids truck, I can see why they regen so much, these motors arent clean burning at all. The filter just catches everything.
imported_DieselKid is offline
post #9 of 19 (permalink) Old 06-19-2007, 11:10 PM
you guys could be getting low sulfur instead of ultra low. even with no filter, the ulsd is supposed to produce next to no smoke.
post #10 of 19 (permalink) Old 06-19-2007, 11:11 PM
what do you not understand fatso?
