F250 vs F350 which to get. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by azdrt, this thread has received 43 replies and been viewed 6651 times.
post #1 of 44 (permalink) Old 06-26-2007, 01:18 AM Thread Starter
I know there are probably 100 threads on this, but going back quite a few pages did not see anything, and doing a search with numbers appears to be hopeless. (IE: f250 vs f350)
I have always owned 1/2 ton gassers, and looking to buy a 3/4 ton diesel... however looking at cost and payload ratings, what disadvantages are there to upgrading to a 1ton?
Is ride firmer? or with the setup of the spring packs is the unladen ride about the same for both trucks?
Seeing as how right now I d not have any toys or trailers, but plan to in the future (LQ horse trailer, possibly a slide in camper), should I save the (roughly) 1grand difference in price and just buy the 3/4 ton, or spend the extra and not be limited down the road.
Spending nearly 50g's for a truck, I don't want to have to trade it in a year down the road, already took a bath unloading a problem child 03 Chevy and know I am going to take a bath on my Charger... (luckily I have alot of equity in it), but don't want to deal with buying more then I need (in terms of ride/service) with daily driving, or if down the road a 3/4 ton is all I will need to do the job.
Any advise welcome.
Oh, and I got the Charger because I always wanted a fun RWD car, and living in AZ now, I was able to get it without dealing with winter driving, but I have always been a truck guy, and am used to off-roading, hunting, etc... things having a car have put a stop on. Plus I work construction, so the car has been an issue, for hobbies, way of life, and work..... :
azdrt is offline
post #2 of 44 (permalink) Old 06-26-2007, 01:22 AM
In all honesty, there isnt much difference in the 250-350...except better payload capacity, and the ride is about the same in either. I would say if you are planning to have trailers like you mentioned, I would get the F-350 and not have to worry about if it can handle the trailers or not.
Go Greyhound, and leave your luggage with us. *maybe not intentionally*
Manual 2500 is offline
post #3 of 44 (permalink) Old 06-26-2007, 01:31 AM
Strokin' and Smokin'
That basically sums it up. The rear axle on the 350's are built for a heavier load. More axle splines and a larger diameter. Don't know the exact specs but I'm sure someone will get them to you before too long. Just got my 3rd 350 and the ride is great and sure can handle a load. Good luck on the new truck.
I'm kinda in the same boat for cars. Traded my 85' CJ-7 for a 70' mustang. Mistake, especially after all the mods I did to that CJ.
2008 F-350 6.4 CC DRW 4x4 Cowboy Edition 6-speed w/3.73 gears
SCT tuned w/5" DPF/DOC delete going into black 6" Aussie Stacks
Keystone Ram air hood feeding a S&B Cold Air Intake
Ranch Hand front bumper, custom headache rack and bed rails, lots of L.E.D.'s, 15 million candlepower H.I.D. GoLight
Black 22.5" Alcoa Big Rig wheels with 36" tires
Buy cialis in online pharmacy - it's cheap and convenient.
Discount prices on phentermine.
SouthTexasDiese is offline
post #4 of 44 (permalink) Old 06-26-2007, 01:33 AM
Powered By Ford
FordRacing200's Avatar
the only difference is the F350 has 2" higher blocks in the rear, it rides the same, just has a higher load rating, I'd get the f350
FordRacing200 is offline
post #5 of 44 (permalink) Old 06-26-2007, 01:46 AM
Here's the specs I mentioned.
Axle Shaft
F250
Spline Minor Dia.(in.) 1.36"
Spline Major Dia.(in.) 1.50"
No. of Splines (Hub End) 35
Capacity (Rating @ Ground) 6200 lbs.
F350srw
Spline Minor Dia.(in.) 1.50"
Spline Major Dia.(in.) 1.57"
No. of Splines (Hub End) 37
Capacity (Rating @ Ground) 7280 lbs.
The 350's comes with a 2" block. It also has auxilary leaf springs standard, while they are optional on the 250's.
post #6 of 44 (permalink) Old 06-26-2007, 01:48 AM Thread Starter
Thanks for the specs bud :HappyMugs
azdrt is offline
post #7 of 44 (permalink) Old 06-26-2007, 01:51 AM Thread Starter
I read about the 2" higher blocks on here or another forum over the weekend... not sure where I saw it... Having always lifted trucks, but thinking of keeping next truck stock for towing.... the factory higher ride peaked my interest as well
azdrt is offline
post #8 of 44 (permalink) Old 06-26-2007, 02:13 AM
I switched to 350's a few years ago just cause i was tired of the sag in my 250's with the trailers loaded. I can honestly say the 250 handled the weight just as good, I just like the look of the truck level when loaded.
2008 F350 4x4 crew cab Lariat 6.4
2007 F350 4x4 crew cab Lariat 6.0
2007 2500hd Silverado LTZ 6.6
jammer is offline
post #9 of 44 (permalink) Old 06-26-2007, 02:38 AM
Powered By Ford
Axle Shaft
F250
F350srw
No no no, the 250 comes with a 2" block and the 350 comes with a 2" taller 4" block. :Thumbup:
post #10 of 44 (permalink) Old 06-26-2007, 02:50 AM
Same concept, 2" tall on 350's
