DPT Deleted? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Toolpusher, this thread has received 11 replies and been viewed 1740 times.
post #1 of 12 (permalink) Old 12-28-2007, 01:07 PM Thread Starter
DPT Deleted?
Hi everyone,
I'm new here and do not know much about diesel. I've been leaning a lot from everyone.
I'm driving a 2008 Ford F-250. The computer shows me that I average 20 MPG going between 55-65 MPH and 18-19 MPG at 65-75 MPH. After a tank and I figured it on paper it comes out to 14-15 MPG with out pull any thing. I think it has a lot to do with the regen system due to it burning extra fuel to clean the filter. My truck will regen 3-4 times per tank. I've seen where people have deleted the DPT so there truck will not regen. The regen is to clean the spicel filter in the exhaust system? If so, by not regening want the filter clog up and cause problems?
Toolpusher is offline
post #2 of 12 (permalink) Old 12-28-2007, 01:47 PM
[QUOTE=Toolpusher]Hi everyone,
I too lean from some of the people here, others aren't that bad.:
I think you mean DPF (diesel particulate filter)?
Those who have shut the regen process off with programming are also physcally removing the DPF to keep it from clogging.
Flor_It is offline
post #3 of 12 (permalink) Old 12-28-2007, 07:38 PM
yeah, if you turn the regen off then you need to remove the dpf, otherwise the soot that gets caught won;t ever get burned off, and you have a much bigger obstruction than you ever had before, hey, STRAIGHT PIPE IT!!!
cajuncummins is offline
post #4 of 12 (permalink) Old 12-28-2007, 08:39 PM
your truck should not regen 3-4 times per tank unless you are doing city driving constantly laying into the throttle, even then 3-4 times is a stretch.
When i do city driving at college i get on the throttle often and the most ive seen is 2 regens in one tank but i was doing a lot of throttle mashing that tank.
ShaunCobb is offline
post #5 of 12 (permalink) Old 12-29-2007, 12:11 AM Thread Starter
I do a lot of short trip back and front to town with out laying into the throttle and that probably why my truck regens so often. Thanks for the info.
post #6 of 12 (permalink) Old 12-29-2007, 12:34 AM
Now Cummins Powered
MRBOHN23's Avatar
I was given some data from my ford dealer and they said that the more highway driving the more chance for regen, because that is when the system will go into that mode more often. Something to do with the more consistant speed. Yes, you will create more soot in the system with more city driving, but the system will try to regen more on the highway then in and around town. Hey, thats what I was told so I just thought I would add that in. :2cents
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #7 of 12 (permalink) Old 12-29-2007, 12:44 AM
TDG MAFIA MEMBER #85
onebadf150's Avatar
I drive 130 miles a day in new orleans traffic with good bite of idling and maybe get the first sign of needing a regen in a 1.5 weeks.
Question, when your truck starts to regen do you let it finsh which take approx 30minutes or do you hit the brake and keep driving?? If you do the later that why your truck is acting that way. If I were you I would either get on the highway and drive for an hr at 70mpg you'll probably clean it out or when it starts to regen open the hood to allow the heat out and let it do its thing for 30minutes.
I always notice after I fill up for diesel and its around the time for a regen I usually get it if the truck is hot already.
onebadf150 is offline
post #8 of 12 (permalink) Old 12-29-2007, 01:40 PM Thread Starter
I did not know hitting the brakes would stop the regen, so no I do not. If it is regenning when I stop at home, I just turn it off. Diesel prices are to high just to let it burn fuel in park to finish regen. I only run on the highway twice a month going to work.
post #9 of 12 (permalink) Old 12-29-2007, 08:26 PM
Strokin' and Smokin'
If you shut the truck off during a regen it will continue the cycle again when the truck reaches operating temp. Let it completly finish, that's probably why you're going into regen so much.
2008 F-350 6.4 CC DRW 4x4 Cowboy Edition 6-speed w/3.73 gears
SCT tuned w/5" DPF/DOC delete going into black 6" Aussie Stacks
Keystone Ram air hood feeding a S&B Cold Air Intake
Ranch Hand front bumper, custom headache rack and bed rails, lots of L.E.D.'s, 15 million candlepower H.I.D. GoLight
Black 22.5" Alcoa Big Rig wheels with 36" tires
Buy cialis in online pharmacy - it's cheap and convenient.
Discount prices on phentermine.
SouthTexasDiese is offline
post #10 of 12 (permalink) Old 12-29-2007, 09:38 PM
onlytapping the brake in park will shut it off. not in drive
kcpanages is offline
