Smoking - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06jimmy, this thread has received 8 replies and been viewed 978 times.
post #1 of 9 (permalink) Old 01-01-2008, 02:00 AM Thread Starter
Images: 2
Smoking
question for you guru's.
Truck has been sitting for about a week. Temperature this morning was 38 degrees. Left for the gym. drove about a mile or two and it began blowing white smoke. that lasted about a mile then stopped. Drove another 8 miles with no smoke. Left the gym 2 hours later. temperature was now 44 degrees. same thing. drove about a mile and it blew white smoke for about a mile then stopped for the last 8 miles. it was smoking while i was cruising, not excelerating. i parked it until i hear some thoughts from some guru's.
any ideas as to what's up?
06jimmy is offline
post #2 of 9 (permalink) Old 01-01-2008, 02:13 AM
condensation in exhaust I.E. what happens when warm air collides with cold in an enclosed space
06 Ram 2500,4X4 QC Laramie,
Not that stock Canadian club member #4
dfranks is offline
post #3 of 9 (permalink) Old 01-02-2008, 01:55 AM Thread Starter
Images: 2
that certainly makes sense. thanks. :thanks:
this morning on the way out to the gym, i took the dog out and started the truck to let it warm up a bit before pulling out. when i did leave, i saw white smoke (condensation) while idling in the driveway.
06jimmy is offline
post #4 of 9 (permalink) Old 01-02-2008, 03:36 AM
Strokin' and Smokin'
Your truck was probably in regen. The cycle kicked on when the exhust was still cold and the diesel pumped into the exhaust didn't burn so it came out as white smoke. After a mile the temp got warm enough to regen properly. If you only drove 10 miles the regen was probably not able to complete, so it started again when you left and you got white smoke from the unburned diesel.
The reason that it smoked at cruise is because while stoped or at low speeds the regen is temporarly shut off as a saftey feature so the truck doesn't take off, so after getting back up to speed the cycle kicks back on and more smoke comes out if the exhaust is cold.
2008 F-350 6.4 CC DRW 4x4 Cowboy Edition 6-speed w/3.73 gears
SCT tuned w/5" DPF/DOC delete going into black 6" Aussie Stacks
Keystone Ram air hood feeding a S&B Cold Air Intake
Ranch Hand front bumper, custom headache rack and bed rails, lots of L.E.D.'s, 15 million candlepower H.I.D. GoLight
Black 22.5" Alcoa Big Rig wheels with 36" tires
Buy cialis in online pharmacy - it's cheap and convenient.
Discount prices on phentermine.
SouthTexasDiese is offline
post #5 of 9 (permalink) Old 01-02-2008, 01:26 PM Thread Starter
Images: 2
Afgain, thanks
06jimmy is offline
post #6 of 9 (permalink) Old 01-02-2008, 02:09 PM
I have had a problem with the smoking for some time. It use to be a problem with smoke in the cab but I have had both down pipes replaced and now it just blows smoke out the exhaust. Today it was cold but the engine was up to temp and I felt the engine go into regen and when I was pulling away from the stop light smoke again. This has occured in both cold and warm ambient air temperatures. Looks like the insect fogging truck when this happens. Any ideas?
bwalker56 is offline
post #7 of 9 (permalink) Old 01-03-2008, 11:58 PM
Learning to smoke
ok i understand condensation and that..... but this wasn't that kind of smoke pouring out of mine this morning it looked like a James Bond movie for about 2 miles then nothing????
FATSO is offline
post #8 of 9 (permalink) Old 01-04-2008, 12:10 AM
TDG #97
2008TTCC's Avatar
SouthTexas hit the nail on the head... It went into regen a little early and then DPF was not hot enough to ignite the diesel fuel, there for all that raw diesel came out un ignited, or as white smoke!
MAFIA #97
RIDIN' HIGH #28
RIDIN' DIRTY #40
SINGLES CLUB #203
B.O.M.B. SQUAD #67
2008TTCC is offline
post #9 of 9 (permalink) Old 01-04-2008, 12:17 AM
Learning to smoke
do you guys promise!!!!! scared the crap out of me...... it's my first time with a diesel..... and it was about 19 degrees on my way to work.....
thanks for all the help this site and the people on it are great
FATSO is offline
