6.4L Engine Temp Slow Coming Up - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Roach, this thread has received 11 replies and been viewed 8016 times.
post #1 of 12 (permalink) Old 01-16-2008, 12:07 AM Thread Starter
Roach
Roach's Avatar
I have a skoesh over 5000 miles on the truck, and when the temp is 20 deg. or a little more, the engine temp is slow to come up, and the heater won't produce heat until it is up somewhat. I asked the dealer, and they said Ford is aware of a problem, and they are working on it. The engine temp isn't even up to the bottom of the normal range, but the trans temp is up about 1/4 the way. Are the guages funky, or is there another problem?
2008 F-350 Lariat Dually, 4X4, Long Bed, Sirus Radio, Prestige Remote Start/Turbo Timer, Retrax Bed Cover, Power Tailgate Lock, Pillar Guages, Pyro, Boost, Trans Temp., chrome door handles, chrome fuel filler door.
Roach is offline
post #2 of 12 (permalink) Old 01-16-2008, 04:16 AM
there are some reports of the thermostat"s sticking open causing a slow to warm up,i have not heard anymmore about it and seen no tsb"s. on your next cold start-up,start the engine then get out and grab the upper radiator hose.
feel the hose to see if coolant is flowing threw it. that will tell you if the thermostat"s are stuck open.
imported_diesel71 is offline
post #3 of 12 (permalink) Old 01-16-2008, 02:32 PM
Now Cummins Powered
MRBOHN23's Avatar
I've noticed the exact same thing!!! This is my first diesel, so I thought it was normal. Guess it isn't. I'll contact my dealership and ask them about it. Thanks for the info Roach.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #4 of 12 (permalink) Old 01-16-2008, 02:52 PM
Now Cummins Powered
MRBOHN23's Avatar
I just called my service tech and he said it can be normal. He said for me to stop by next time im in the area, but that he doesn't think there is anything abnormal with the motor taking much longer to heat up than the tranny.
MRBOHN23 is offline
post #5 of 12 (permalink) Old 01-16-2008, 03:30 PM Thread Starter
Roach
Roach's Avatar
I am judging the time to warm up with the time that it took to warm up my '05 6.0. I am going to be going to North Dakota in the near future, and I definately want heat coming out of the heater. The engine temp guage was bad in my '05 and gave a false high temp reading, therefore the fan kicked on, and lost alot power until the needle came back down to normal. I was wondering if the temp guage is maybe bad in this one, and giving the opposite indication. I really do love this truck, except for the fuel mileage.
Roach is offline
post #6 of 12 (permalink) Old 01-17-2008, 09:09 PM
In cold temps at a idle it will take forever to warm up. I would use the high idle and see if it warms up faster. Not sure on the 6.4s but on my 6.0 All I had to do was connect 2 wires under the dash to get the high idle to work. I used the one of the AUX switches.
07 3500 5.9 QC LB AT 4x4 Edge Additude w/hot unlock S&B intake 5" Magnaflow exhaust
Trucks Sold
93 F250 7.3 Turbo SC LB 5 Speed 4x4 XLT Stock
2006 F350 6.0 CC LB AT 4x4 King Ranch SCT etc
2003 F350 7.3 SC LB AT 4x4 XLT H2E and more
1993 F250 7.3 LB IDI 2wd 5 speed XL Pump turned up
ontherks is offline
post #7 of 12 (permalink) Old 01-17-2008, 11:35 PM
Diesels take 4-5 miles to warm up. I have a 95 F-250 PSD and it takes a few miles to warm up. My diesel VW Jetta takes 5 miles to warm up. Get grill plugs to cut off cold air over the engine, or block the air off with cardboard or solid fabric (vinyl) or something, to allow a faster warmup. And plug her in to warm the block up before you go, it will speed warmup and give better oil flow sooner.
thegrinch is offline
post #8 of 12 (permalink) Old 01-18-2008, 11:36 PM
my 6would be throwing heat in a few minutes at idel even in 20 degree temps..if your engine isnt warming up,,it needs a thermostate,,i wouldnt even mess with the atealer. just buy one and throw it in there.
fred43 is offline
post #9 of 12 (permalink) Old 01-19-2008, 02:10 AM
the 6.4 has 2 thermostat"s in 1 housing so he would need 1 with bypass and 1 without bypass and a housing gasket.
post #10 of 12 (permalink) Old 01-20-2008, 09:13 PM
Heat
I have the same problem, the truck takes more than 5 miles to warm up. All I can say is thank GOd the heated seats work real well. If I knew this was going to be a problem I would have gotten the quick heat feature. I should have known something if they offered that. First Diesel, still learning. Ford is still winning, first ford in over 20 years.:shrug:
twinsberry is offline
