High idle mod. Only 900rpms? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryansdad, this thread has received 13 replies and been viewed 1317 times.
post #1 of 14 (permalink) Old 01-25-2008, 04:37 PM Thread Starter
ryansdad's Avatar
Hey guys, hooked up the correct wires(not the PTO wire) for the high idle mod and first time I hit the switch this morning it went up to around 1400rpms. I thought, "cool!". I've flicked the switch a few times since then and it only goes up to 900rmps. Has anyone had this happend to them before? I did the mod on my '05 and it always worked fabulously. Any thoughts?
Jeff
ryansdad is offline
post #2 of 14 (permalink) Old 01-25-2008, 05:33 PM
ZeroOne's Avatar
Normal for BCP (battery charge protection). Stays high at first start because of the glowplugs and whatnot. After the truck is warmed up and the electrical load drops, it tops out at 900. The PTO wire will give you a solid 1200rpm. If you wanted more than that, you could use pto and a resistor on the wire that sets the pto-rpm and get all the way up to 2400, if I remember correctly.
ZeroOne is offline
post #3 of 14 (permalink) Old 01-25-2008, 05:40 PM
ZeroOne's Avatar
Here, this is from another forum that I had posted on a while ago. Might be useful over here for some people too.
:Thumbup:
For PTO @ 1200rpm its a yellow/green wire. You just use a butt-splice and hook that wire to which ever upfitter you decide to use. Start the engine, parking brake applied, trans in park, and flip the upfitter. The engine will smoothly climb to the 1200rpm. It will NOT regen in PTO mode, or so the Ford document had stated.
You pull off that panel below the steering wheel... the upfitter bundle and the add-on bundle are to the far left, above the parking brake mount, about 3 inches apart. Here is a pic. I have both SEIC and BCP, just to try them both out.
PTO (the yellow/green wire), will idle to 1200rpm, but there is another wire you can add a resistor or potentiometer to, to change the "PTO" idle speed (all the way to 2400rpm). BCP is the purple/brown wire, and will hang at 900rpm and idle up from there depending on electrical load, (hence "BCP", Battery Charge Protect).
Here is the pic...
ZeroOne is offline
post #4 of 14 (permalink) Old 01-25-2008, 10:26 PM Thread Starter
ryansdad's Avatar
How do you pull the panel off? I didn't want it to break since it was about 30 degrees when I did this.
ryansdad is offline
post #5 of 14 (permalink) Old 01-25-2008, 11:04 PM Thread Starter
ryansdad's Avatar
Thanks for your help guys! I connected the PTO wire up and it works great!
ryansdad is offline
post #6 of 14 (permalink) Old 02-04-2009, 07:39 PM
supr87gt's Avatar
Takes about 5 min to do it guys! I hooked PTO to #4. Any chance there's a different wire to hook to the switch so you dont have to use the e-brake? I dont want to deal with resistors or any of that crap so if not, it's not a big deal.
But good advice for anyone looking to do this mod.
supr87gt is offline
post #7 of 14 (permalink) Old 02-04-2009, 08:57 PM
O2ShootTheJ's Avatar
yea im thinkin about doin this but would need a more instructional post
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #8 of 14 (permalink) Old 02-04-2009, 09:14 PM
DieselFarmer's Avatar
there were some really good links and post that people had on this high idle mod. Like said earlier it only takes 5 min. i remeber having a bunch of printed paper telling me which wire was wich annd then spliced them and hooked them up. wish someone would post the link to the ford upfitter site.
2008 F-250 Lariat 4x4 Silver
Mods Engine:
Spartan 310, 4in downpipe, 4in flo-pro exhaust, AFE intake, TCM, 3in CAC pipe
Transmission: Fully built Suncoast
Suspension:
Carli 4.5" suspension system, King Coilover shocks, rear Deaver spring pack, Xd Moster wheels, 35" Toyo Mt's
Exterior:
Buckstop Bumper, Warn 16.5 Ti winch, Warn HID lights, HID headlights, Backrack, weatherguard toolbox, Twin Viar 480C compressors, B&W turnover ball hitch
http://i554.photobucket.com/albums/j...26-09012-1.jpg
DieselFarmer is offline
post #9 of 14 (permalink) Old 02-04-2009, 09:42 PM
supr87gt's Avatar
This what you are talking about?
https://www.fleet.ford.com/truckbbas/non-html/Q162.pdf
supr87gt is offline
post #10 of 14 (permalink) Old 02-05-2009, 01:01 AM
what are the advantages to the high idle mod?
Singles Club #222
December 2008 TOTM
Riding High Club #2
Big Thanks to:
