Common Rail Fuel Pump Location???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Still Strokin, this thread has received 3 replies and been viewed 993 times.
post #1 of 4 (permalink) Old 02-03-2008, 05:01 PM Thread Starter
Still Strokin's Avatar
I just realized international put the pump under the engine cover on the back of the engine to suppress it from noise. Did duramax do the same? I thought there's was external on top of the engine? Or is that just in a Dual CP3 setup?
2009 F-350 Lariat, Black, CC/LB SRW 6.4L, Torqueshift, 4x4 Off Road, Every Option, Moonroof, Audiophile, LED Light Bar, B&W Hitch, 5% Rear Tint, 30% Front Tint, 5% Sunstrip, Level Kit, LT-325-60-20 BFG AT's on 20x10 Dale Jr.'s , Custom 7 1/2 ft. Traction Bars, Stroker's 5" DOC/DPF Delete, 6"x36" Mitre Cut Stacks, Spartan Dash Daq, SCT Livewire, River City Diesel Beta Files, 311 Lope Sled Pull File. SDT 310 & 350 Files
WWW.MYSPACE.COM/44SKILLET
Still Strokin is offline
post #2 of 4 (permalink) Old 02-03-2008, 10:11 PM
the d-max pump is in front of the engine down low in the valley,it"s driven off the front camshaft gear.
imported_diesel71 is offline
post #3 of 4 (permalink) Old 02-04-2008, 10:55 PM Thread Starter
I figured it was something like that. I knew it had to be cam driven to stay in time.
post #4 of 4 (permalink) Old 02-05-2008, 01:25 AM
dzljon's Avatar
The High pressure fuel pump is located on the back of the engine under the turbo's it is cover by a panel.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
