Boost Pressure Change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by volwing, this thread has received 11 replies and been viewed 1179 times.
post #1 of 12 (permalink) Old 02-05-2008, 09:21 PM Thread Starter
Would like to understand how the boost pressure changes. For instance while in cruise control I started going up a slight incline and noticed the RPM's appeared to stay the same but the boost pressure jumped form less than 10psi to app. 20psi. Still the RPM's remained unchanged and I maintained the set speed. It must have something to do with the extra fuel flow from the cruise control...how does this work?
volwing is offline
post #2 of 12 (permalink) Old 02-05-2008, 09:27 PM
more stres on the engine causes the boost to go up. So while your going up a hill theres more of a load on the engine.
thanks
imported_fast_and_furious is offline
post #3 of 12 (permalink) Old 02-06-2008, 10:45 PM Thread Starter
Thanks for your response. What is the stress? Does the boost pressure indicate the compression of air entering the manifold? If the RPM's don't change how does the turbo increase the air pressure since it is the exhaust gases that spins the fan? How much is the inlet air temperature increased in proportion to the boost pressure increase? I know the purpose of the intercooler is to reduce the air temp resulting fromt the boost pressure. Just would like to understand the mechanics involved.
volwing is offline
post #4 of 12 (permalink) Old 02-06-2008, 11:11 PM
Superdutytd's Avatar
Images: 3
Load/exhaust velocity is what dictates how much boost. Not RPM. You're thinking of a supercharger.
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #5 of 12 (permalink) Old 02-06-2008, 11:53 PM
08powersmoke's Avatar
couldn't have said it better myself
2008 f250 4x4, auto, 3.73
spartan tuned..
37x13.50r20 interco ssm16
pioneer z3 navi, and a few other ear goodies...
B.O.M.B SQUAD #20
RIDING DIRTY CLUB #35
RIDIN' HIGH #23
SINGLES CLUB #199
08powersmoke is offline
post #6 of 12 (permalink) Old 02-07-2008, 01:23 PM Thread Starter
Loading the engine increases boost pressure. OK but what I am asking is what mechanically results in the gauge showing a change? Does a doubling of boost pressure also double the air temperature? The manual says not to run at a high boost pressure for extended time periods. Is this because of the temp. becomming so high that the engine is damaged?
volwing is offline
post #7 of 12 (permalink) Old 02-07-2008, 05:05 PM
Former Ford AutoTrans Eng
Mark_K's Avatar
As the truck starts up the grade the PCM adds fuel to make more power. The RPM stays the same because the torque converter remains locked. The additional fuel makes more heat in the exhaust, and this heat drives the turbocharger faster. The faster turbocharger compresses more air, resulting in more boost. Boost is just pressure in the intake manifold.
Doubling boost does not necessarily mean the air temp is doubled. It isn't a linear relationship, and it is further complicated because there is an intercooler, which cools the air between the turbo and the intake manifold.
Mark
Former Ford Automatic Transmission Engineer 1988-2007
Mark_K is offline
post #8 of 12 (permalink) Old 02-07-2008, 07:34 PM
ZeroOne's Avatar
Don't the variable vanes in the turbo adjust to ramp up boost also? Sortof a more aggressive pitch for more air.
ZeroOne is offline
post #9 of 12 (permalink) Old 02-08-2008, 07:33 AM
Hydro's Avatar
Yep, the second (larger) turbo is variable vane'd and will respond as Mark explained.
Hydro is offline
post #10 of 12 (permalink) Old 02-14-2008, 02:07 PM Thread Starter
Thanks for all the responses. I found a source that explained the process of how the turbocharger adds power while keeping the RPM the same. Know that the ratio of air to diesel fuel must remain the same. The turbo spins as a result of the exhaust pressure and temperature. The pressure is proportional to the demand on the pistons. As the vehicle begins to need power the resistance of the piston increases. More compression is required to push the piston back. This increases the pressure and temp of the exhaust gas. In turn the turbo responds to the pressure and temp increase. The computer senses the spin increase and incremenatally adds fuel to the cylinder thus yielding more explosive power. The boost increases power while RPM stays constant. Of course your MPG goes down. A remarkable way of increasing an engine's power using the same displacement.
volwing is offline
