FS2500 external oil filter installed (pics) !! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by onebadf150, this thread has received 19 replies and been viewed 3883 times.
post #1 of 20 (permalink) Old 03-03-2008, 09:19 PM Thread Starter
TDG MAFIA MEMBER #85
onebadf150's Avatar
Thumbs up FS2500 external oil filter installed (pics) !!
well I installed the fs2500 about a month ago and it was an easy install but it took alot of time about 6 hours. Its not hard but you have to drill the frame and there are fuel lines in all the spots you can choose so u have to be very careful I used a piece of sheet metal taped to the backside of the frame as a stop for the drill bit so it didn't hit the lines. Also since its a universal kit I had to hide 4 feet of oil line since I got an extended cab short bed. I didn't follow the directions on where to mount the filter and how to run the lines I did it the way I thought was best. Also very important to Teflon tape all the connection even the ones they tell you not to tape I learned my lesson on the 6.0L you will get an oil leak and you will have to drain and redo not fun. I'm going to pull a oil sample at 3000 miles to see how its working.
here's the pics !!!
onebadf150 is offline
post #2 of 20 (permalink) Old 03-03-2008, 10:42 PM
git-r-done
TSGS69400's Avatar
Looks great. Hope it provides better protection. Did yoy have good luck with it on the 6.0? Notice any advantages first hand?
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #3 of 20 (permalink) Old 03-03-2008, 11:07 PM Thread Starter
onebadf150's Avatar
on the 6.0L I never did any oil testing but I plan on it with the 6.4L. I will tell you that the truck feels smoother. I would also suspect that the oil stay cooler due to the added distance it travels and area of the filter. I will post my oil sample results.
post #4 of 20 (permalink) Old 03-04-2008, 12:07 AM
SeaPig
seapig's Avatar
Good job Nick:bow:
Can't wait to call you so you can help me with mine:Thumbup:
~Mike~
[B]2008 F-450 Lariat 4x4 6.4L PSD LWB DRW 4:88's
seapig is offline
post #5 of 20 (permalink) Old 03-04-2008, 02:28 AM
Looks nice and clean
let us know how it helps.
F350 PSD SRW King Ranch
11.8 @ 120mph on 37s
8700 lbs.
Spatel23 is offline
post #6 of 20 (permalink) Old 03-04-2008, 03:16 AM Thread Starter
onebadf150's Avatar
you got it :Thumbup:
post #7 of 20 (permalink) Old 03-04-2008, 03:17 AM Thread Starter
onebadf150's Avatar
Originally Posted by seapig
Good job Nick:bow:
~Mike~
mike, I thought you could use a little motivation to get yours on !! :evil: :
post #8 of 20 (permalink) Old 03-04-2008, 10:57 AM
SeaPig
seapig's Avatar
Oh you are bad
Just waiting to put it in when I hit my 10,000 mile mark my friend.
I am looking forward to it.
You were not kidding were you. That is a LOT of extra line ya got there:
~Mike~
seapig is offline
post #9 of 20 (permalink) Old 03-04-2008, 02:23 PM
:smoke
I just installed an FS-2500 on my PSD last week. The installation went well, about two hours. The hard part was drilling a hole in the frame without hitting anything important.
I researched all the bypass oil filters I could find and settled on the FS-2500 as it seemed to be the best out there. Granted, it is a bit pricey, about $550, with stainless hoses. I plan to drive my PSD as long as possible and believe this to be a small investment with hopefully a long term payoff.
What I don't like about this filter set-up is that the oil return goes back to the engine through a hose attached to a replacement oil drain plug causing the new drain plug, 90 degree elbow and hose to protrude down about 2 to 3 inches below the oil pan. This is terrible for off roading and even bad for city driving should you accidentally run over something in the street. I understand that they have an optional oil return available that I believe goes to the oil fill tube. I'm going to be installing that soon on my PSD.
The link below will let you see a demonstration of how effective it filters.
http://filtrationsolutionsww.com/fs-2500_video.htm
Good luck with it!
huston is offline
post #10 of 20 (permalink) Old 03-04-2008, 03:21 PM
Yeah, that return line on the pan scares me... Hope the new fill cap comes soon.. You should convert to that...
DelfinoTX is offline
