Temp #'s needed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by broth, this thread has received 10 replies and been viewed 1282 times.
post #1 of 11 (permalink) Old 01-14-2009, 09:02 PM Thread Starter
Temp #'s needed
I need some #'s guys. I am specifically looking for ECT & EOT #'s empty. Pulling would help as well but more so when you are empty (please make sure to included how much weight for towing). Please also included if you are stock or which tune you are running.
Ford is telling me that EOT 220-230 empty is Ok as long as ECT is with in 30 degrees?? I say ok but once I tow then they (EOT) shoot through the roof.....
Everything else runs awesome just the dam EOT and they have replaced the water pump and say that the oil cooler is fine??? I will print this and bring it to them to show what others are running.
Thanks in advance for your help!!!!!
broth is offline
post #2 of 11 (permalink) Old 01-14-2009, 10:40 PM
How did they test the engine oil cooler. Sounds like a oil cooler to me. Should never jump like they say more than 30 degrees tops.
2008 F-350 C/C Long Bed 4x4
cattech05 is offline
post #3 of 11 (permalink) Old 01-14-2009, 10:51 PM
mmayo's Avatar
your EOT is still that high empty?
mine runs anywhere from 200-208 under normal conditions.....pushing it hard empty will see up to 215
ECT is usually 5 or so degrees cooler?
only when towing can i see the 220s for EOT
F350 King Ranch LWB 4x4
mmayo is offline
The Following User Says Thank You to mmayo For this addition to TDG:
broth (01-15-2009)
post #4 of 11 (permalink) Old 01-15-2009, 12:22 AM
Wow! Until a few weeks back, my truck never (almost never, rather) rose above 192-194. But now completely empty I will see 196-202.
On my most recent trip from OKC to Abilene, TX, I saw EOT's between 208-215 or so. And that was towing about 10-12k (i've never weighed my truck and trailer). That was also heading dead on into a constant 20mph wind with 40-50mph gusts. The outside temp was something like 70ish i believe.
Crown Vic Guy is offline
The Following User Says Thank You to Crown Vic Guy For this addition to TDG:
broth (01-15-2009)
post #5 of 11 (permalink) Old 01-15-2009, 04:55 AM
Spartan, True Performance
mick1955's Avatar
Seems a little high to me. Here's the reading from my wife's truck, stock F350 SRW 4x2, engine coolant temp 196, engine oil temp 195.8, Speed 70, outside air temp around 75f.
Here's my post on another forum where I was pulling 21,000. Truck is as F350, Dually 4x4 with 4.10 rear-end, running the Spartan 210 tune.
I just pulled 21,000 with the 210 tune. Truck had plenty of power. Outside temp 65 degrees. Egt's running 60-65 were high, 1000-1100 and sometimes climbing small hills hit 1200. Soon as I slowed, would get it down between 1000-1100. Boost at same speed was 34-36, but and as high 45 while I was trying to get up to speed. Highest I saw EOT was 221, and ECT was 212.
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
The Following User Says Thank You to mick1955 For this addition to TDG:
broth (01-15-2009)
post #6 of 11 (permalink) Old 01-15-2009, 11:26 AM
Running both the 210 and 275, northern VA winter temps ranging from low 20s to 60s I see 192-194 on EOT, a few degrees cooler on ECT. Unloaded, normal driving and to and fro...3:73 rear end on a FX4 CC.
Craig02711 is offline
The Following User Says Thank You to Craig02711 For this addition to TDG:
broth (01-15-2009)
post #7 of 11 (permalink) Old 01-15-2009, 02:57 PM Thread Starter
I am not sure how they tested the oil cooler but that is what I think it is as well??? I am going to get them to swap it out.
Yeah when I tow I get get well over 240 and have even seen some higher EOT that I don't want to remember. I would be fine with 220 when I was towing but it just seems too high. Even during those high temps I have seen truck ran fine actually ran awesome!!!
What do you guys think about getting the an oil sample tested? Will that tell me anything in regards to heat??
broth is offline
post #8 of 11 (permalink) Old 01-15-2009, 08:19 PM
My EOT is around 196-200
Cody6405 is offline
The Following User Says Thank You to Cody6405 For this addition to TDG:
broth (01-15-2009)
post #9 of 11 (permalink) Old 01-15-2009, 10:46 PM
mmayo's Avatar
i would get it tested- is it still in the truck???
mmayo is offline
post #10 of 11 (permalink) Old 01-15-2009, 11:11 PM Thread Starter
Yeah I was thinking about getting it tested. the oil you mean?? Yeah it is still in the truck.
broth is offline
EGT TEMP ?'s 1bAdmAx Duramax 2001-2004 (LB7) 4 01-13-2009 09:00 PM
Gear Temp rises before Coolant Temp? kizzzottt 2003-2007 6.0L Power Stroke 4 02-26-2008 09:31 PM
oil temp and coolant temp strokin6L 2003-2007 6.0L Power Stroke 5 02-14-2008 02:28 AM
Temp 88 Centurion 7.3L and 6.9 IDI (Pre 1994) 1 04-14-2007 05:40 PM
More important to monitor oil temp or coolant temp? imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 15 08-23-2006 03:08 PM
