water filled cyls? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by budtoh3zo, this thread has received 7 replies and been viewed 848 times.
post #1 of 8 (permalink) Old 01-14-2009, 11:07 PM Thread Starter
water filled cyls?
A guy i know had his truck idleing for 4 hrs to charge the batterys on his truck bc they were dead and shut it off and the next time he went to start it was locked up, just like it was sized, so he got it towed to ford they ripped it down and found 2 cyl full of water? If mine is idled for long i take it for a run before shutting her down witch might be a good practice?. just a heads up and brain scratcher.
budtoh3zo is offline
post #2 of 8 (permalink) Old 01-14-2009, 11:28 PM
DieselFarmer's Avatar
Yea this is why people install high idles like I did to raise oil pressure and maintain engine temp in all temperatures. High idle also makes for a complete burn of fuel preventing this issue. It is called wet stacking when a diesel engine runs at a low rpm for a extended period of time such as in this case. Diesel engines like to be run at higher rpm's while idling. This is good evidence of wet stacking and this problem that some people ignore cause they cant see. Just as you said it is proper practice to run a diesel for a little while after it has been idling at low rpm's it allows for burnoff of built up condensation and unburnt fuel.
DieselFarmer
DieselFarmer is offline
post #3 of 8 (permalink) Old 01-14-2009, 11:33 PM Thread Starter
I got hi idle on mine and even with that run it after, but i was just shocked and wondering if it could all be condasation? I know alot of ppl say wet sacking is a myth but this is proof its not.
post #4 of 8 (permalink) Old 01-15-2009, 12:14 AM
sledneck57's Avatar
Its not a myth. And no there's no way condensation would do that.
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Ridin Dirty Club #37
sledneck57 is offline
post #5 of 8 (permalink) Old 01-15-2009, 01:09 AM Thread Starter
were could that amount of water come from then? or could it be a water/diesel mix?
post #6 of 8 (permalink) Old 01-15-2009, 02:29 AM
I Eat Rice
forcefed6.4ford's Avatar
The real question should be what FORD considers to be "full of water". Weather it be 2tsp or half a litre.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #7 of 8 (permalink) Old 01-15-2009, 02:53 AM Thread Starter
yeah thats true, all i know is it was enough to hydro lock it and only 2 cyl. would have been nice to get a pic or something.
post #8 of 8 (permalink) Old 01-16-2009, 11:38 PM Thread Starter
Just alittle update, he went to get his truck today and found the EGR valve stuck open as well. if that had anything to do with it or not there not saying, but i can kinda see it with the water vapor that comes out of the exhust.
466 water in oil yamadog Medium and Heavy Duty 4 12-10-2007 12:45 AM
Water In Oil Help!!!! cumminspower121 5.9L Cummins 12 Valve (1994-1998.5) 20 10-21-2007 06:27 AM
It all started when I filled up at the Flying J in Eloy, Arizona..... Trulyvintage 7.3L and 6.9 IDI (Pre 1994) 10 04-13-2007 03:22 AM
filled gas by mistake *HELP** strokin Duramax 2001-2004 (LB7) 12 03-17-2007 03:19 PM
Cement and rain filled post holes??? jschall The Parking Lot 10 06-24-2006 09:25 PM
