No Boost - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sandbox, this thread has received 7 replies and been viewed 7137 times.
post #1 of 8 (permalink) Old 01-14-2009, 11:13 PM Thread Starter
No Boost
Does anyone know why a 6.4L would not build boost?
As I was driving home from work today, I noticed that my truck would not hold a consistant boost pressure. It seemed as though the small turbo would build up to about 10psi but then the larger turbo would not kick in and the boost would drop to 0psi. I noticed this while driving about 60mph after I had been sitting in stop-and-go traffic for about a half an hour. While I observed this, I went through the system check in the message center and it said that the exhaust filter was being cleaned.
However after shutting off the truck and running into the bank the problem seemed to go away.
Sandbox is offline
post #2 of 8 (permalink) Old 01-14-2009, 11:23 PM
that is normal, everytime it goes into a regen you will notice that, its limiting the air so it can raise the egt's so its hot enough to burn the soot off. also if you got a new flash if you push it hard enough the boost will build but then fall right back off if you let go. its all normal. Also when you shut the truck off and started it again then it would not be in a regen for alittle while till it plugged the filter off enough to call for one again.
budtoh3zo is offline
post #3 of 8 (permalink) Old 01-14-2009, 11:24 PM
O2ShootTheJ's Avatar
did you check the intercooler boots?
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #4 of 8 (permalink) Old 01-15-2009, 12:54 AM Thread Starter
Thanks,
I figured it had something to do with the regen, but this is the first time this happened with 2000mi on the truck. Could the below freezing temperatures account for this situation?
Sandbox is offline
post #5 of 8 (permalink) Old 01-15-2009, 01:07 AM
have you being idleing lots? it could be a more aggressive regen then your used to if its more plugged off. With mine since i do lots of idleing around with work if it gets plugged off bad enough it will start to regen as soon as i take it out of park.
post #6 of 8 (permalink) Old 01-18-2009, 09:15 PM Thread Starter
I have been idling quit a bit with this cold weather.
This happened to me again today (500mi later) except this time, "Drive to clean exhaust system" popped up in the message center. How exactly do you drive to clean the exhaust?
Sandbox is offline
post #7 of 8 (permalink) Old 01-18-2009, 10:07 PM
You just drive atleast 30 mph to clean it it takes about 20 min of driving.
post #8 of 8 (permalink) Old 01-19-2009, 05:26 PM
Powered By Ford
FordRacing200's Avatar
delete that stupid EPA mandated hunk of scrap metal.... www.spartan.com
FordRacing200 is offline
Raising Boost, Meth Injection, Boost controllers, etc.... Stinger23 1994-2003 7.3L Power Stroke 14 04-15-2008 09:35 PM
Turbo Boost No Boost Burner718 1994-2003 7.3L Power Stroke 16 04-02-2008 04:14 AM
DT-360 Boost Mopar Doctor Medium and Heavy Duty 12 04-29-2007 04:07 AM
how much boost? chosen1 1994-2003 7.3L Chips & Tuners Forum 4 03-26-2007 03:25 AM
Boost????? rocweiller 2003-2007 6.0L Power Stroke 27 04-20-2006 09:42 AM
