QUESTION : RE : contamination of oil with fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by quick83, this thread has received 10 replies and been viewed 1580 times.
post #1 of 11 (permalink) Old 01-15-2009, 05:30 PM Thread Starter
quick83's Avatar
Hey guys, just want an education on this subject. How much if any fuel is suppose to get into the oiling system in 5,000 miles between oil changes. I never owned a desiel before this and do not know if its normal to gain some oil on the dip stick between oil changes. thanks for any information and an education on this subject.....roy
quick83 is offline
post #2 of 11 (permalink) Old 01-15-2009, 06:50 PM
TDG MAFIA MEMBER #85
onebadf150's Avatar
not sure what the exceptable level would be but I sampled my oil twice and no fuel present in oil.
onebadf150 is offline
post #3 of 11 (permalink) Old 01-15-2009, 09:25 PM
Hydro's Avatar
Ford is saying up to 6% is acceptable in the 6.4L?
I'm only passing on what another forum said which had this same discussion.
I too on my last oil change had a level above full and they did a leak test on my injectors and it passed.
Hydro is offline
The Following User Says Thank You to Hydro For this addition to TDG:
quick83 (01-16-2009)
post #4 of 11 (permalink) Old 01-15-2009, 11:49 PM
dieselgem's Avatar
Yes it is normal to get some fuel in the oil. It is due to the regen process. If you are towing heavy you could gain several quarts in 5,000 miles.
2008 F450-
2008-41'CKS KZ Escalade Toyhauler
http://www.dieselgem.shutterfly.com
dieselgem is offline
The Following User Says Thank You to dieselgem For this addition to TDG:
post #5 of 11 (permalink) Old 01-16-2009, 11:20 AM Thread Starter
quick83's Avatar
thanks guys....6% of 15 quarts....= one qt, that would def show a little high on the dip stick, and an other thing these dip sticks are hard to read, some oil allways smeared on and above the white marking area making it hard to tell if oil over the white area or not, seems to settle out on the white plastic area showing full with some on the metal part of dip stick also above the white area on the metal. I towed a 8000 lb TT about 4000 miles of the 5000 since last oil change. I just got the newest reflash and really like that it tells me when in regen and that does not do it anymore in "P" or "N"....thanks again for the info.
quick83 is offline
post #6 of 11 (permalink) Old 01-16-2009, 12:00 PM
harry6.0's Avatar
Also one thing to remember is, not to overfill the oil during a oil change. This is a common mistake that some people and oil change people make, they fill it to the high mark on the dipstick with cold motor oil. Oil expands with heat, just as most anything does. When refilling the oil after an oil change its best common practice not to fill the oil to more than halfway on the dipstick reading between the low and full marks. The halfway reading should be after running it a few minutes and then letting it settle for at least 5min after the oil change, then read the dipstick, it should read around halfway. After driving your vehicle to full operating temps and you go to recheck your oil, it will likely read near or at the full mark after the oil has expanded. Harry
harry6.0 is offline
The Following 2 Users Say Thank You to harry6.0 For this addition to TDG:
Hydro (01-16-2009), quick83 (01-16-2009)
post #7 of 11 (permalink) Old 01-16-2009, 03:51 PM
Hydro's Avatar
Harry, that's great advice. I have also been told to NOT just throw 15 quarts in and call it a day for that reason. People seem to notice that 15 quarts puts it to the top of the dipstick, even with a filter change.
Hydro is offline
post #8 of 11 (permalink) Old 01-16-2009, 04:32 PM
pyro2nite's Avatar
I have tested my oil the last 4 changes, Blackstone Labs, and it is around 2.1%. Stock. That was both heavy towing and empty, 5000 miles between changes. Now I don't know if Ford considers this normal because I can't get an answer from the dealer what is normal.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #9 of 11 (permalink) Old 01-16-2009, 05:20 PM Thread Starter
quick83's Avatar
hydro, yep that's me...I had the dealer do mine and they say they will put in 15 qt because that what ford calls for. I have a 75,000 mile/7 year warentee and only put about 7,000 miles a year on it and cause I get them to do all my oil changes they own my engine till I hit 7 years or 75,000 miles(I hope). I know warentee claims can not work out the way you think sometimes.but hopefully with all changes done there they will have to cover engine wear etc due to overfull or fuel in oil. hope I never have to find out.
quick83 is offline
post #10 of 11 (permalink) Old 01-16-2009, 05:35 PM Thread Starter
quick83's Avatar
desielgem.....nice freakin rig!!!!! some day.....I have a 2000 prowler26' TT since new. some day I WILL get a 5th wheel now that I have the correct truck to tow it with. your livin the dream. I'm a mustang guy and have a heavly modified 83 convertible. nice bikes also, have you ridden the blue ridge?
quick83 is offline
Alt Fuel! Tired of Traffic? HOV lane Bi-fuel F150! - $10000 taztruck Whats Been Sold 0 01-04-2009 04:13 PM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
Fuel leak from fuel filter drain tube Diezel Dawg 1994-2003 7.3L Power Stroke 11 02-02-2007 01:47 PM
