P006b dtc - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by badford93, this thread has received 6 replies and been viewed 6521 times.
post #1 of 7 (permalink) Old 01-18-2009, 03:00 PM Thread Starter
badford93's Avatar
P006b dtc
its says on the DTC list its MAP/Exhaust Pressure Correlation..i only get that light when its cold out and im starting the engine cold. never get it any other time and the truck has the spartan 250 on it if thats any help...just wonderin what that crap means lol
badford93 is offline
post #2 of 7 (permalink) Old 01-18-2009, 03:03 PM
Diesel Kid
Super08Duty's Avatar
Did you check the Pressure sensor on the DPF/DOC? I would check all the sensors just in case.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #3 of 7 (permalink) Old 01-19-2009, 12:02 AM Thread Starter
badford93's Avatar
i didnt check them figured if i didnt have a prob with the 5000 miles i put on it in the warmer months why should i have one in the colder months?!?
post #4 of 7 (permalink) Old 01-19-2009, 12:16 AM
Diesel Kid
You never know, the plastic part of the Pressure Sensor just pops right off of the Metal Part. It should be fine unless you notice something is wrong.
Colton
post #5 of 7 (permalink) Old 01-19-2009, 05:02 PM Thread Starter
badford93's Avatar
ya i just clear the code..it runs fine when the codes on and all the temps are normal.
post #6 of 7 (permalink) Old 01-19-2009, 05:29 PM
I like Pretty Girls!
Hollywood's Avatar
how cold is cold? If I start mine (Not plugged in) -10c and lower it sounds really rough for about 20 seconds then it clears up, if it does that sometimes it throws a code or two.
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #7 of 7 (permalink) Old 01-19-2009, 07:55 PM Thread Starter
badford93's Avatar
mine will be prob about 20degrees F for maybe lower but if its any lower than that unplugged then it starts a lil rough then smooths out but throws the code im sure its somethin not to worry about cuz no one has chimed in and said itll mess somethin up lol. cuz if its plugged in or warmer out theres no code thrown just wonderin if its drawin more air then stock upon start up becasue its cranked up on the 250hp tune and has the S&B intake so its readin too much airflow because the code pertains to MAP/Exhaust pressure sensor
