new check engine code - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nordberg, this thread has received 4 replies and been viewed 922 times.
post #1 of 5 (permalink) Old 01-19-2009, 03:32 PM Thread Starter
nordberg's Avatar
i got a p2563 turbo boost code on saturday. i thought i read somewhere that this was a cold weather related code so i thought id post it up to check and see.
08 f250 6.4
stock?
nordberg is offline
post #2 of 5 (permalink) Old 01-19-2009, 03:39 PM Thread Starter
nordberg's Avatar
ok i found it on the .org site. it does sound to be cold weather related.
08 f250 6.4
stock?
nordberg is offline
post #3 of 5 (permalink) Old 01-19-2009, 03:45 PM
bushpilot's Avatar
you running a tuner ?? boosting higher than "stock" ?
Don R.
Truck Audio,
bushpilot is offline
post #4 of 5 (permalink) Old 01-19-2009, 03:51 PM Thread Starter
nordberg's Avatar
yes, im running a phalanx, boost was relatively low when the light came on ( i was driving amout 10mph accross a lake. alos this is with the 150 tune
08 f250 6.4
stock?
nordberg is offline
post #5 of 5 (permalink) Old 01-19-2009, 05:06 PM
I Eat Rice
forcefed6.4ford's Avatar
I got it last Saturday. And it was about 30deg F outside. Others have been throwing the same code when it was bitterly cold out but seemed to go away when it warmed up.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
need help with a check engine light code destructive 2003-2007 6.0L Power Stroke 7 12-05-2007 03:46 AM
Engine code hubcap 5.9L Cummins (2003-2007.5) 2 08-27-2007 02:14 PM
Code check may be EGR. montauk 2003-2007 6.0L Power Stroke 0 06-12-2007 11:02 PM
engine code truck545 Video Discussion & Support 1 05-27-2007 02:40 AM
fuel rail pressure check engine code jroderick 5.9L Cummins (2003-2007.5) 3 04-21-2006 02:32 AM
