Really thinking about DPF delete - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rutcutter, this thread has received 17 replies and been viewed 3739 times.
post #1 of 18 (permalink) Old 01-21-2009, 11:24 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Im REALLY thinking about doing the dpf delete now that I have about 40k on the rig thinking I have all the bugs worked out. Im wanting to do the easiest swap possible incase I have to reinstall everything again for warranty work.
So guys that have been there and done that tell me what to go with,I really dont want to mess with pulling the stock sensors just want to drop it and install the delete system in full.
Guru's give me some tips and how much those sensors cost.
If someone is close to me that has done it a few times please chime in as I may need alittle help..
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #2 of 18 (permalink) Old 01-22-2009, 12:09 AM
powerstroker67's Avatar
Clean and easy swap, full CAT/DPF pipe. This allows you to remove the assemble in one piece, you don't even have to put a socket or wrench on the nuts that hold the two together. Sensor should run about $80 each on the EGT ones, if the truck was built Jan 07 or later all three are the same number. As far as pressure sensor, if you run one of my pipes you dont even have to remove the fitting from the pipe. You will just remove the pressure sensor off the brkt and pull the rubber hose off the nipple on the factory pipe. Very, very clean and easy. Let me know if you need any help.
SPARTAN SCT + H+S TUNERS IN STOCK,SAME DAY SHIPPING TIL 5PM
NEW 6.4 COOLER ONLY DELETES, 6.7 COOLER DELETES BUILD INHOUSE!!!
ONE PIECE, BEST FITTING, AND USA MADE CAT/DPF 3.5,4 AND 5 CUSTOM APPLICATIONS AVAILABLE
[email protected]
www.streetdieselperformance.com
(860)250-6082 Sean tech questions
www.dpfdeletekits.com
(919)636-1518 Aaron sales
2011 F350 Lariat, CC,SB,SRW H+S MINI,CAT/DPF W/ full 5" Magna, 8" Procomp, American Force 22",37" Dunlop Maxx Tractions
2008 F450 Lariat,4X4,4.88's,Job1,Loaded,Spartan310,TCM,SCT w/ Eric's tunes,Elite studs+EGR delete,Updated Head gskts.,POWERSTROKER67 CAT/DPF pipe,AFE,Suncoast T/C,Spearco
powerstroker67 is offline
post #3 of 18 (permalink) Old 01-22-2009, 02:28 AM
ZeroOne's Avatar
I have powerstroker67's pipe and it was very easy with the full-delete. The only sensor I'd consider getting a 2nd one of is the rear-most EGT. That thing was a nightmare to remove. The others took seconds, each.
Besides the obvious, the only other thing I can say is that I took the exhaust hangers right off the frame rather than fight those stupid rubber things trying to pop them off and smash up knuckles.
There are quite a few threads that give the step by step order of things.
ZeroOne is offline
post #4 of 18 (permalink) Old 01-22-2009, 02:40 AM
Big_Dezel's Avatar
Send a message via Yahoo to Big_Dezel
I would go with powerstrokers set up. My egt sensors came out easy. Just sprayed some pb blasted on them and used a 13mm tubing wrench. I did totally remove the front hanger and left the rest on there. It's pretty simple really.
Big_Dezel is offline
post #5 of 18 (permalink) Old 01-26-2009, 05:34 AM
i need help also
my truck is in regenaration mode and cant get it out
i cut and made my own delete pipe how do i get it out of this mode
congoboy is offline
post #6 of 18 (permalink) Old 01-26-2009, 05:54 AM
Rudy@DPFDeleteKits's Avatar
Do you have DPF Delete tuning installed? If not, you need to either get a SCT or Spartan programmer. Let me know if i can help in any way.
SCT LIVEWIRE 9625OR, SPARTAN TUNERS, AND DPF DELETE KITS IN STOCK! SAME DAY SHIPPING!
*WE WILL BEAT ANY ADVERTISED PRICE, GIVE US A CALL*
Toll-Free Sales # 1-866-757-6537 or (919) 636-1518
http://stores.shop.ebay.com/Rudys-Pe..._sopZ15QQ_scZ1
post #7 of 18 (permalink) Old 01-26-2009, 08:57 AM
help
my truck is stuck in regenation mode how do i get it out
congoboy is offline
post #8 of 18 (permalink) Old 01-26-2009, 09:27 AM
no i do not have the tuner tell me what i need and get it packed up everthing i have the truck min the congo so i need all parts at 1 time
congoboy is offline
post #9 of 18 (permalink) Old 01-26-2009, 10:10 AM
Congoboy, It's not as easy as just removing the DPF and CAT and installing a pipe. You have to have have a program that will stop several things including the regeneration process. Spartan can help you. You need a DD and specific tuning/calibration to make it run correctly. I hope this helps
08-450dually is offline
post #10 of 18 (permalink) Old 01-26-2009, 10:30 AM
nickdoni's Avatar
I have the spartan tuner and the dpf delete pipe. If i do the full delete pipe you offer would the high pressure vaccume cleaner sound go away? Would the truck be louder?
nickdoni is offline
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
Just thinking again. wastedwagesracing The Parking Lot 6 04-10-2008 05:38 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
