pro's con's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerman, this thread has received 17 replies and been viewed 2859 times.
post #1 of 18 (permalink) Old 01-27-2009, 08:55 PM Thread Starter
pro's con's
I am thinking about getting a new truck and want to know all the pros and cons of all the new trucks. I am going to make this thread on all three forums (ford, dodge, gm).
I am basically wanting to know about the issues that have been common with the new trucks and real world MPG. I do know more about the dodge's and ford's than the gms.
Dodge: 17+ mpg can be had, DPF get clogged up from idling...
Ford: a ton of 12/13 MPG trucks out there, radiator problems...
GM: ?
Those are the types of things I am looking for. If you want say what you think is great about each or bad about each.
powerman is offline
post #2 of 18 (permalink) Old 01-27-2009, 11:06 PM
Diesel Kid
Super08Duty's Avatar
There arnt that many problems. I love mine and havent had any problems with it. Radiators are a problem with some.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #3 of 18 (permalink) Old 01-27-2009, 11:18 PM
Spartan, True Performance
mick1955's Avatar
Well, need a little more information! Are you talking about a F250, F350, or F450? Two wheel drive or four wheel drive. Single or dually, and which rear-end? As far as the truck, we have two and both are great, and running the Spartan tunes. Almost 16,000 miles on the dually and the best mileage I've been able to get so far is 14.9 running between 60-63. That's with a 4.10 rear-end. The other truck is two wheel drive with less than 2000 miles. Haven't checked the mileage on it. No problems at all so far!!!! I would have to say that these are the nicest truck we have ever owned.
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #4 of 18 (permalink) Old 01-28-2009, 02:22 AM
mattbracing's Avatar
I had 3 chevys (02 8.1 gas motor, trans broke 1st gear at 50k,, 03 duramax trans blow up at 55k transfer case craped out at 70k ,,06 druramax rearmain seal 40k trans oil cooler lines were allwayes leaking fixed 3 differnt times) We have haid fords as our work trucks and ran them till 200k and the bigest problims we have have haid is starters going out and a few other little things the 3 fords that we have had have never put us down and every chevy that i haid has that is why my personal truck is now 08 powerstroke 4 door fx4 short bed and i love it
mattbracing is offline
post #5 of 18 (permalink) Old 01-28-2009, 11:36 AM Thread Starter
350, not sure on single or dually, 3.73 rear end, 4x4
powerman is offline
post #6 of 18 (permalink) Old 01-28-2009, 02:16 PM
lilpooh's Avatar
I,ve got the same kind of thread started,so if you don't get many replys look for a thread "any known issues". I also have this started in all three new truck forums.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #7 of 18 (permalink) Old 01-28-2009, 02:44 PM
Ive got a job1 truck I bought April 2007 with 30k miles and the only warranty work Ive had done is a leaking shock on front that I had replaced. I bought the venturi hose kit and installed it. I havent had radiator issues yet. Fuel mileage is up thanks to Spartan. Over all I would buy this truck again, again, and again. Quality of this truck is way better than Dodge and I would say the new Chevy is a better built truck than it was 5 years ago. If I didnt buy this truck I would proly buy a chevy...
2008 F350 Crew Cab 4WD 6.4 Spartan Tuned
Dav700 is offline
post #8 of 18 (permalink) Old 01-29-2009, 04:08 PM
I can say that the 08 Ford over the 06 Ford is night and day. Super quiet, smoother power, smoother ride, interior style, excellent powertrain, and the seats! Awesome truck. After my 06 problems I swore I would never buy another Ford, but I wanted a truck that would haul something without air bags and there was no other option. Ford did a great job with this truck and I hope they don't screw it up with the new Scorpion.
Mr.Tourettes is offline
post #9 of 18 (permalink) Old 01-29-2009, 04:33 PM
Now Cummins Powered
MRBOHN23's Avatar
Well, I can tell you that the 08-09 ford superduty's are very nice trucks. I have an 08 250 lariat and love it. Biggest problem I had was a ticking noise which happens after every oil change for the first couple hundred miles. Ford says not a big deal and its normal? Otherwise the truck is comfortable roomy, quiet and draws a lot of positive comments. I would buy another and may buy mine when the lease is due up. Good luck. I heard dodges have some problems with the transmissions, and their dpf system. Gm's I'm not too sure about because I don't know anyone who has a new one. I know the duramax motor is a beast though.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #10 of 18 (permalink) Old 02-03-2009, 01:54 AM
GM: ?
I don't know about your Dodge mpg#s, my nephew has one and hasn't seen better than 13.5 hand calculated, stock,jfyi.
buckslayr is offline
Pro's and Con's powerman 6.7L Cummins (2007.5-2011) 5 02-03-2009 06:39 PM
SCT Livewire Help from the Pro's Fasteddie08 2008-2010 6.4L Engine Tuner Forum 6 01-16-2009 10:30 AM
pro's and con's betweem MBRP and just cut down pipe? 96stroker 1994-2003 7.3L Power Stroke 7 04-09-2008 03:15 PM
Pro's-Con's of AT 545 Intrailhunter Medium and Heavy Duty 4 04-07-2008 02:46 AM
need the pro's to pipe up!!!!!!!! TANK'S 250 2003-2007 6.0L Power Stroke 9 03-08-2006 03:09 AM
