Supplemental heater testing? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rutcutter, this thread has received 10 replies and been viewed 1687 times.
post #1 of 11 (permalink) Old 01-30-2009, 10:07 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
I was wondering if anyone with a manual could tell me how the techs test to see if the supplemental heater is working or not,mine doesnt seem to be working..
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #2 of 11 (permalink) Old 01-31-2009, 02:52 AM
Did it ever really work? When I test drove one at 4 degrees outside it didn't seem to get any warmer faster. Thats the only reason I didn't put one in my truck when I ordered mine. Maybe I was supposed to let the truck idle for more than 15 minutes.
2008 F-350 C/C Long Bed 4x4
cattech05 is offline
post #3 of 11 (permalink) Old 01-31-2009, 05:58 AM
Superdutytd's Avatar
Images: 3
Mine gets warm after about a minute and doesn't blow 100 degree air but blows air that is a hell of a lot warmer than like 20...
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #4 of 11 (permalink) Old 01-31-2009, 05:36 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Does anyone with a service manual have the procedure the techs use?
2011 SD F350 6.7L
post #5 of 11 (permalink) Old 01-31-2009, 05:50 PM
Why don't you take it to the dealership and have them check it out?
post #6 of 11 (permalink) Old 01-31-2009, 06:42 PM Thread Starter
Mafia member #6
Rutcutter's Avatar
Cause I can see if it works or not myself,then if it doesnt i'll take it in..
2011 SD F350 6.7L
post #7 of 11 (permalink) Old 02-07-2009, 05:53 PM
Mine doesn't seem to work real well either. I was expecting to feel a difference.
Mbixler is offline
post #8 of 11 (permalink) Old 02-08-2009, 12:56 AM
Buy a cheap bulb weather thermometer and hold it near the vent. That's the same test the techs use for A/C, just with more sophisticated thermometers. But you really should feel the difference. It takes about 30 seconds to flush the cold air from the plenums. Its warm, not hot so don't expect TOO much, but it is nice. Also the owners manual says it works best on low to medium fan settings, so it must be a small or low powered element. For those that asked: Its an electric element, so letting the truck idle to w2arm it has no effect
yukondiesel is offline
post #9 of 11 (permalink) Old 02-10-2009, 12:23 AM
Still Strokin's Avatar
I was having the same problem with mine. Do this. Start the truck with the blower off and then turn your temp up to 90 degrees or just the hottest setting. Then turn your defront on and run it at half fan speed. Like right in the middle. Ok, check the air temp when you first turn the defrost on and then take the thermometer away. Let the truck run 2 minutes and check it again. It takes awhile but trust me its working. My truck get's pretty warm inside as long as you run it at no higher than medium fast speed. Even when the heat gauge hasn't moved it still blows pretty good warm air
2009 F-350 Lariat, Black, CC/LB SRW 6.4L, Torqueshift, 4x4 Off Road, Every Option, Moonroof, Audiophile, LED Light Bar, B&W Hitch, 5% Rear Tint, 30% Front Tint, 5% Sunstrip, Level Kit, LT-325-60-20 BFG AT's on 20x10 Dale Jr.'s , Custom 7 1/2 ft. Traction Bars, Stroker's 5" DOC/DPF Delete, 6"x36" Mitre Cut Stacks, Spartan Dash Daq, SCT Livewire, River City Diesel Beta Files, 311 Lope Sled Pull File. SDT 310 & 350 Files
WWW.MYSPACE.COM/44SKILLET
Still Strokin is offline
post #10 of 11 (permalink) Old 02-10-2009, 12:51 AM Thread Starter
Mafia member #6
Rutcutter's Avatar
I always wonder cause I leave mine in the auto setting no matter what the temp,so the next cold day I will run it in manual mode and take a temp reading. Thanks for the tips.
2011 SD F350 6.7L
testing RussK Testing 1 01-14-2009 05:15 PM
testing block heater? BigRed97 1994-2003 7.3L Power Stroke 5 01-22-2008 02:27 AM
6.9 Testing? danktank6.9 7.3L and 6.9 IDI (Pre 1994) 2 12-22-2007 09:15 PM
New guy, just testing JohnPShoe Introductions 9 01-23-2007 02:46 AM
