Batteries - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SEABEE08FX4, this thread has received 17 replies and been viewed 2007 times.
post #1 of 18 (permalink) Old 02-05-2009, 02:49 AM Thread Starter
R.I.P. DAD
SEABEE08FX4's Avatar
Batteries
Anyone on here ever use marine starter batteries as replacments in there trucks? I have a bad cell in one of mine and I can get a sweet deal on some marine batteries. 1000 marine cranking amps.
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #2 of 18 (permalink) Old 02-05-2009, 02:59 AM
What is the Cold Cranking amps? What is the reserve caoacity? That will tell you alot . I do not know the difference if any Between marine and regular ole cranking amps. Sorry.
2001 Dodge quadcab 4x4,Auto transmission,Fass 150/150 pump, Among other upgrades.
todt061458 is offline
The Following User Says Thank You to todt061458 For this addition to TDG:
SEABEE08FX4 (02-05-2009)
post #3 of 18 (permalink) Old 02-05-2009, 03:02 AM
I Eat Rice
forcefed6.4ford's Avatar
Marine hold more reserve capacity. More CCA the better. with a 1000 you could drive into town on the starter. .
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
The Following User Says Thank You to forcefed6.4ford For this addition to TDG:
post #4 of 18 (permalink) Old 02-05-2009, 03:07 AM Thread Starter
R.I.P. DAD
Its 1000 marine cranking amps and 800 cca, not sure on the reserve capacity though.
2008 F-250 FX4
FOSP Club # 1
post #5 of 18 (permalink) Old 02-05-2009, 09:27 AM
Superdutytd's Avatar
Images: 3
Those are the same as the stock batteries I beleive. The Optimas i'm looking at putting in my Ex have 1000 amps at 32 degrees and 800 at 0 (CCA'S)
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
The Following User Says Thank You to Superdutytd For this addition to TDG:
post #6 of 18 (permalink) Old 02-05-2009, 11:44 AM
bushpilot's Avatar
if you can get em in 12v / sized to fit theyd be a good option...especially if your
trucks SITS for extended periods of time...even if you have a maint. charger.
but the word MARINE (equipment) usually means $$$$$
Don R.
Truck Audio,
bushpilot is offline
The Following User Says Thank You to bushpilot For this addition to TDG:
post #7 of 18 (permalink) Old 02-05-2009, 03:32 PM
bushpilot's Avatar
heres a good read -
There are many types of batteries available, of course which one is right for you? For audio installations, experience has shown that the best results will be obtained using deep-cycle marine batteries. These batteries can be obtained from almost any dealer for approximately $60. Lead-acid batteries are preferred over calcium-based (maintenance-free) batteries because of their superior internal characteristics. Maintenance-free batteries are usually designed to provide a large amount of current for a short period of time. This is great for starting your car, but not so great for running a high-powered system.
Deep-cycle marine batteries, on the other hand, are designed to provide a moderate-to-large amount of current over a long period of time. The plates in each cell are thicker, and they are made for deep, cyclic use. This is important because you can severely drain this type of battery without damaging it, which is ideal for car audio installations.
There are three ratings you should check out when selecting a battery. The first is the CCA (cold-cranking amps) rating. This indicates a battery's ability to provide a large amount of current for a short period of time at cold temperatures. (If you're looking for a battery that will be used just to start your car, this is the rating you would be most interested in.)
The second rating, and the one that is most important in terms of your system, is the AH (amp/hour) rating. This rating simply states how much current the battery is capable of delivering for a period of time. The larger the rating, the better. Typical deep-cycle marine batteries have AH ratings of 85 to 105.
The third rating you should look at is reserve time. Deep-cycle marine batteries really shine here. Reserve time represents the battery's ability to recover and produce electrical energy after a discharge cycle without re-charging. The longer the reserve time, the better.
Don R.
Truck Audio,
post #8 of 18 (permalink) Old 02-05-2009, 11:10 PM Thread Starter
R.I.P. DAD
Thanks Don thats a good read, I can get these cheap like 60 a pop just like the artical says. I'll have to check the amp hr and reserve cap when I look at them again.
Thanks again everyone.
2008 F-250 FX4
FOSP Club # 1
post #9 of 18 (permalink) Old 02-06-2009, 01:13 AM
bushpilot's Avatar
let me know...im in need of TWO myself !
Don R.
Truck Audio,
post #10 of 18 (permalink) Old 02-06-2009, 01:23 AM Thread Starter
R.I.P. DAD
Will do, gotta work Fri but i'm doing this on Sat so I will report my findings.
2008 F-250 FX4
FOSP Club # 1
Batteries gone bad Diezel Dawg 1994-2003 7.3L Power Stroke 11 01-06-2009 03:12 PM
My Batteries took a cr&p jdydiesel General Ford Truck and Excursion 8 04-09-2008 05:15 AM
Batteries albzzz General Ford Truck and Excursion 7 03-10-2008 02:06 AM
Batteries 7.3stroker281 1994-2003 7.3L Power Stroke 8 01-06-2008 03:04 PM
Batteries powerstroke7.3 1994-2003 7.3L Power Stroke 12 10-25-2007 11:53 PM
