Probes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Farmboy162005, this thread has received 3 replies and been viewed 750 times.
post #1 of 4 (permalink) Old 02-10-2009, 11:05 PM Thread Starter
Probes
What do the four probes measure in the exhaust system. I have already began to investigate them by pulling them out one by one, and one cleaning the soot off of them and two seeing if the truck still runs.
Well with the first and last out the truck will run and the middle two they dont let the truck run. So with that in mind if i make a delete pipe or buy one will the truck run if the probes are plugged into the pipe with out a delete tune?
2008 F-250 Lariat 4x4, 4 Door, Moon Roof, Air Lift, Line-X, XM & Sirius, More godies to come
Current Fleet:
99 F-250 XLT 246k, 00 F-250 XLT 208k, 00 F-550 XL 83K, 03 F-350 Lariat 133k, 05 F-650 Pro Loader 93k, 05 F-350 Lariat 37k, 06 F-250 King Ranch 87k, 05 3500 Duramax 106k, 08 3500 Cummins 4k.
Equipment:
3 OMC Shakers, 3 Flory Sweepers, 3 Raymaker Sweepers, 2 TN95 Tractors, 2 Weismacnare Harvestors, 3 Thomas Shuttles, 2 Thomas loaders, John Deere 8430, John Deere 9520, 3 Dresser TD-40, Dresser TD-20, Komatsu D-65, 3 CAT D-10L, and 2 more TD-40's to come
Farmboy162005 is offline
post #2 of 4 (permalink) Old 02-11-2009, 12:05 AM
TDG #97
2008TTCC's Avatar
Your truck will go into constant regen point blank period. You need a tuner.
MAFIA #97
RIDIN' HIGH #28
RIDIN' DIRTY #40
SINGLES CLUB #203
B.O.M.B. SQUAD #67
2008TTCC is offline
post #3 of 4 (permalink) Old 02-11-2009, 01:46 AM
yea ur truck wont run and u will def need a tuner try spartan they are good im doing about 12.8 in a quarter mile with nitrous and the dpf cat delete air intake and the 275 tune the truck kicks ***
o8fordcompletlystock is offline
post #4 of 4 (permalink) Old 02-11-2009, 03:52 PM
The three probes are EGT sensors and the fourth is the DPF pressure sensor.
Craig02711 is offline
The Following User Says Thank You to Craig02711 For this addition to TDG:
Farmboy162005 (02-13-2009)
Lets talk Pyro replacement probes lilgsx 2003-2007 6.0L Power Stroke 2 09-08-2007 02:37 AM
EGT Probes - Edge vs. Autometer? sredish 2003-2007 6.0L Power Stroke 10 02-09-2006 01:12 AM
