Front End Alignment Issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRedDually, this thread has received 2 replies and been viewed 1397 times.
post #1 of 3 (permalink) Old 02-21-2009, 03:21 PM Thread Starter
Just Cowboy Up and Do It!
BigRedDually's Avatar
I don't know if this is a diesel engine (weight) issue, or a dually issue, or a 1 ton issue, or a 4x4 issue so I'll just throw it out and no doubt get some opinions.
Slightly over 40,000 miles, already replaced both front factory Continentals because they wouldn't balance. Current front tires have less than 20,000, and the outside shoulder of the RIGHT FRONT tire is shot. I had the front end aligned at 20,000, when the front tires were replaced under warranty. I had it aligned again at 30,000, when I swapped the two front tires because the outside shoulder of the RF tire was wearing worse than anywhere else. Now the current RF outside shoulder is wearing.
Truck does not pull one way or the other, and drives perfectly.
Poor tires? Probably. Poor alignment? Possibly. Poor luck? Definitely!
I will be replacing all six tires shortly, (and not with Conti-tracs!), and just wondering if anyone else had had these issues with the right front tire specifically?
'08 F350 CC Lariat DRW
Ordered 12/15/06 Built 02/13/07 Delivered 02/28/07
6.4 L PSD, Auto, Tow Boss, Off-Road
Ranchhand Grill Guard, Headache Rack, Brown's Running Boards
Transferflow 98gal Bed Tank
B&W Turnover Ball, FMJ Spray-in Bedliner
F-450 Front Fender Flares
Airaid CAI
Spartan Tuned 275HP
Red
Dually Club #83
Originally Posted by [email protected] View Post
Any part that you make that is expressly designed to remove a functioning emission component is illegal.
BigRedDually is offline
post #2 of 3 (permalink) Old 02-21-2009, 04:11 PM
I Eat Rice
forcefed6.4ford's Avatar
Sounds like bad tires.
I will never stop amazing me. $70,000 for a truck and put on the road with the cheapest tires possible. Tires are the most important piece of safety equipment on your truck.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 3 (permalink) Old 02-21-2009, 08:59 PM
Now Cummins Powered
MRBOHN23's Avatar
Sounds like you should locate the most reputable 4x4 company in your area and take the truck there to have it aligned. They may be able to help steer you in the right direction as far as the best tire to use as well. I think that is what I would do if I was having the same problem. Good Luck.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
Alignment help please LiftedDuramax Duramax 2001-2004 (LB7) 1 12-12-2007 03:42 AM
Alignment powerstroke2003 General Ford Truck and Excursion 1 09-16-2007 04:56 AM
High altatude smoking & passenger front wheel clunking & electrical issue hauling4you 7.3L and 6.9 IDI (Pre 1994) 1 08-29-2007 03:40 AM
Alignment Issue imported_DagObx 1994-2003 7.3L Power Stroke 4 10-19-2006 10:56 PM
the Mack needs an alignment dondiesel444 Medium and Heavy Duty 20 01-17-2006 03:24 AM
