Particles in Trany Fluid?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselFarmer, this thread has received 11 replies and been viewed 1694 times.
post #1 of 12 (permalink) Old 02-22-2009, 08:42 PM Thread Starter
DieselFarmer's Avatar
So I got home today and let the truck sit for about 10 minutes and decided to check the fluids. The oil was fine so i went to check the Tranny Fluid. It was red like its supposed to be but on the bottom of the dip stick were small particles... not real fine like you would find on a magnetic oil plug but they were noticeable.
Could this have been burnt clutch material?
I checked the level again after wiping the dip stick clean and more were present on the dip stick!!!
Kinda worried bout this. also there are 23,000 miles on the truck and Tranny flud has never been changed.
Anyone have any ideas?
Thanks Diesel Farmer
2008 F-250 Lariat 4x4 Silver
Mods Engine:
Spartan 310, 4in downpipe, 4in flo-pro exhaust, AFE intake, TCM, 3in CAC pipe
Transmission: Fully built Suncoast
Suspension:
Carli 4.5" suspension system, King Coilover shocks, rear Deaver spring pack, Xd Moster wheels, 35" Toyo Mt's
Exterior:
Buckstop Bumper, Warn 16.5 Ti winch, Warn HID lights, HID headlights, Backrack, weatherguard toolbox, Twin Viar 480C compressors, B&W turnover ball hitch
http://i554.photobucket.com/albums/j...26-09012-1.jpg
DieselFarmer is offline
post #2 of 12 (permalink) Old 02-22-2009, 08:44 PM
Powered By Ford
FordRacing200's Avatar
what color is the fluid? if its still red its probably just from break-in, should do the fluid after a 5k mile break-in..I'd change the fluid out and filter and see what happens. Small particles are normal during break-in but big pieces aren't...my friend took out what looked like gravel from his 700r4...needless to say it didn't last another month
FordRacing200 is offline
post #3 of 12 (permalink) Old 02-22-2009, 09:25 PM Thread Starter
I am gonna change the fluid in the tranny. the stuff i am seing is about the side of a pencil tip but there is quite a bit of it on the dip stick when i check the level
also the color is still red a little light tho
Mods Engine:
Suspension:
Exterior:
post #4 of 12 (permalink) Old 02-23-2009, 12:06 AM
samething here after my fluid had been changed.I noticed it about 1200 mi ago.47000 mi on the truck now.I was worried at first still shifts fine.I will have dealer look at it next fluid change.
08 F250
SPARTAN DPF DELETE
PIONEER AVICD3
178MX is offline
post #5 of 12 (permalink) Old 02-23-2009, 02:02 AM Thread Starter
well this is defenatly not what tranny oil should look like. just to compare i pulled the stick on the duramax and it was red and slick. the fluid in my ford is gritty! like really fine sand almost?
Any Ideas?
Duramaxfarmer
Mods Engine:
Suspension:
Exterior:
post #6 of 12 (permalink) Old 02-23-2009, 12:26 PM
Now Cummins Powered
MRBOHN23's Avatar
Does your truck slam into gear sometimes? Mine will shift extremely hard sometimes and violently jolt the truck. My trans fluid is the same way and I just dropped it off at ford.
2004.5 Dodge 2500 Quad Cab Cummins Powered, Laramie, Tow Pkg., Snow Plow Pkg., 4.10 Rears.
2008 Ford F-250 Crew Cab Lariat, 6.4 Powerstroke, Snowplow Prep, Automatic 3.73 posi, 18 inch wheels, SOLD!!!!
MRBOHN23 is offline
post #7 of 12 (permalink) Old 02-23-2009, 04:44 PM
Powered By Ford
Yeah I've never heard of that many particles, definitly shouldn't be like sand, its common to get some shavings in the drainpan on the magnet, but from the way you talk I'd say something isn't right, but its odd the fluid is still light and not burnt up and black
post #8 of 12 (permalink) Old 02-23-2009, 09:34 PM Thread Starter
Guess what Problem solved! So i took the truck into ford today to do a full transmission flush and had them drop the tranny pan and i asked to look inside. the inside was clean with just the normal metal stuff on the magnet. the dirt and grit that i was getting when i pulled the dip stick was actually on the inside of the dip stick tube! so the stick may not have been all the way in or may have worked itself loose somehow and a little dust or dirt stuck to the oily surface inside the tube. fluid was fine but better safe than sorry.
We all learn from stuff like this that is the good thing. The service tech cleaned it out and said there was some dusty small particles that came out of the top of the tube. Problem solved better safe than sorry
Dieselfarmer
Mods Engine:
Suspension:
Exterior:
post #9 of 12 (permalink) Old 02-23-2009, 10:40 PM
Now Cummins Powered
MRBOHN23's Avatar
Hum, guess I will check mine or Ill hear about it from Ford. Good looking out bud.
MRBOHN23 is offline
post #10 of 12 (permalink) Old 02-24-2009, 10:52 AM
quick83's Avatar
I pulled my dip stick last eve after reading this and yea, I had some kinda crumbly debris on the end of the dip stick. after cleaning and reinserting it 3-4 times it came up clean, wonder what the hell that could be, kinda strange. I have org fluid with 10,000 miles on it. will prob get it changes when get time and money.
LUCK IS WHERE OPPORTUNITY MEETS PREPARATION.
quick83 is offline
Ats Trany!!! Fireguy 2003-2007 6.0L Power Stroke 9 09-04-2007 02:07 AM
Trany fluid pumps in N but not P?????? mesadavectd 5.9L Cummins (2003-2007.5) 18 07-03-2007 05:29 PM
For Sale DTT trany KBaucom Whats Been Sold 0 08-27-2006 08:35 PM
Trany Died. Smokem 5.9L Cummins (1998.5-2002) 11 03-12-2006 06:37 AM
