Help. How the &*%# do you inflate tires on a dually? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08-450dually, this thread has received 12 replies and been viewed 13296 times.
post #1 of 13 (permalink) Old 02-26-2009, 04:19 AM Thread Starter
Going on a long trip tomorrow and the dually valves are facing away from me. This sucks! Im new to dually's and just realized the valves are pointing away from me. How do you guys do it??
08-450dually is offline
post #2 of 13 (permalink) Old 02-26-2009, 04:29 AM
Spartan, True Performance
mick1955's Avatar
Sounds as tho that you are not having too much fun. I got an air chuck that has a handle with a gauge on it. Look like the one in this link. Hope this helps.
http://www.northerntool.com/webapp/w...Bchuck%2Bgauge
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Phalanx Flash Console, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
http://spartandieseltech.com/index.p...5-tech-support
mick1955 is offline
post #3 of 13 (permalink) Old 02-26-2009, 04:40 AM Thread Starter
Oh, hi Mick. How are you??
Well, it's not that i'm not having fun, I'm suppose to travel 7 hrs in the am to trailer home a 5th wheel RV and went to check the tires tonight and "surprise"...! :
I've read the owner's manual and there is a caution about having people stand away while putting in air...are they kidding...how the heck am I suppose to put air in it without injuring myself if the tire lets go?
ps. thanks for the link
post #4 of 13 (permalink) Old 02-26-2009, 04:44 AM
mick1955's Avatar
Doing fine! Yes sir, I know how it goes. Using a regular air chuck for getting them aired up is a pain in the butt. It can be done, but not an easy task. Good luck, and hope you have a safe trip.
DD Help File
mick1955 is offline
post #5 of 13 (permalink) Old 02-26-2009, 04:37 PM
Strokin' and Smokin'
I use one very similar to the air chuck he pointed out in the picture. Fina one that has a gauge on it an it will make life much easier. I fill up my F-350 and my M35A2 Deuce and a half with it, 16 tires!!! No way I could pull it off with a regular short chuck.
2008 F-350 6.4 CC DRW 4x4 Cowboy Edition 6-speed w/3.73 gears
SCT tuned w/5" DPF/DOC delete going into black 6" Aussie Stacks
Keystone Ram air hood feeding a S&B Cold Air Intake
Ranch Hand front bumper, custom headache rack and bed rails, lots of L.E.D.'s, 15 million candlepower H.I.D. GoLight
Black 22.5" Alcoa Big Rig wheels with 36" tires
Buy cialis in online pharmacy - it's cheap and convenient.
Discount prices on phentermine.
SouthTexasDiese is offline
post #6 of 13 (permalink) Old 02-26-2009, 07:02 PM
Diesel Kid
Super08Duty's Avatar
We have one similar to the one above. It sucks if you dont have one.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #7 of 13 (permalink) Old 02-27-2009, 12:19 AM
You have got to watch when you get new tires. They can put the wheels on so the outside wheel blocks the inside wheel valve stem completely.
2008 F450 6.4 diesel dually loaded.
2x6 bulldog is offline
post #8 of 13 (permalink) Old 02-27-2009, 02:20 AM
Diesel Kid
thats how my dads dually is, Makes me soo made when i go out to it to check the pressure. :
Colton
post #9 of 13 (permalink) Old 03-02-2009, 01:58 AM
Take it to a place that works on trk tires and ask if you can use their air hose. Don't worry about blowing up a tire unless you damaged the sidewall or really over inflate it. Check for bulges in the sidewalls or tread area to make sure that you are not getting seperation.
heavyhaller is offline
post #10 of 13 (permalink) Old 03-02-2009, 03:49 AM Thread Starter
Thanks, guys. You won't believe it, but I went to the dealer cause I really needed to get the right pressure (was going to haul a 14,500 lbs toy hauler) on the tires and even they were having a hard time getting it right! I don't feel bad now. Going to buy one of those fancy chucks.
Dually tires NEWFY 5.9L Cummins (2003-2007.5) 2 03-09-2008 08:02 PM
Dually Tires Logan General Ford Truck and Excursion 7 02-22-2007 08:54 PM
Dually tires johnboy 5.9L Cummins (2003-2007.5) 1 10-09-2006 05:56 AM
dually tires mossertrucking General Dodge Discussion 0 04-13-2006 04:17 AM
Dually Tires 350FORD 2003-2007 6.0L Power Stroke 10 11-01-2005 10:24 PM
