New coolant reservoir - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mschwing82, this thread has received 17 replies and been viewed 8957 times.
post #1 of 18 (permalink) Old 02-26-2009, 02:52 PM Thread Starter
Images: 1
Had to bring my truck into ford for a new radiator (2nd time) it was also blowing white smoke and had water in the oil. They had to replace the cover that seperates the water pump from the engine. I guess if air gets in the system it causes the pump to cavitate and eats through the cover. They replaced everything and when I got it back it had a new coolant reservoir, there is only 1 nipple that goes to the line that has the venturi "T" and then to the EGR valve. Also the fill line is lower.
mschwing82 is offline
post #2 of 18 (permalink) Old 02-26-2009, 04:18 PM
Diesel Addict
DINOONE's Avatar
Looks like they know they have a huge problem and thier trying to fix it with out doing a proper recall! I wonder did they change you over to the new EGR valve. Think you could take a pic of the EGR valve?
2008 Harley Davidson F250 16" Custom Lift, Modded to Hell and beyond! "CEREAL KILLA"
Truck FOR SALE:
http://cgi.ebay.com/ebaymotors/ws/eB...category=39415
DINOONE is offline
post #3 of 18 (permalink) Old 02-26-2009, 04:55 PM Thread Starter
Images: 1
No new EGR valve the coolant line still runs through it.
post #4 of 18 (permalink) Old 02-26-2009, 06:04 PM
surveyor13's Avatar
Interesting. That is where my coolant level sits all of the time on my truck. Will see if we get a letter from Ford.
2012 Ford F350 Tuxedo Black King Ranch, 6.7L Powerstroke, SRW, Long Bed, 20" Wheels, etc......
Traded: 2011 Ford F350 White Platinum Tri-Coat, 6.7L Powerstorke Turbo Diesel, Lariat Ultimate Package, 20" Wheels, etc.......
*SOLD* 2008 Ford F-250, Black with Pueblo Gold, 6.4L Turbo Diesel, 285 65 R20E BF Goodrich All Terrains.
2006 Triton TR20X Bassmaster Classic Edition
surveyor13 is offline
post #5 of 18 (permalink) Old 02-26-2009, 07:50 PM
pyro2nite's Avatar
Looks like Ford expects a little “expansion”. If that was the low water mark with the old bottle, then how could the system work when it’s the new high water mark? Remember don't overfill your system.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #6 of 18 (permalink) Old 02-26-2009, 09:11 PM
surveyor13's Avatar
Can you give us some information on your truck? Year, Job build?
post #7 of 18 (permalink) Old 02-27-2009, 04:04 AM
looks like they lowered it by quite abit. got to wonder why they cant get there marks right the first time.
budtoh3zo is offline
post #8 of 18 (permalink) Old 03-02-2009, 02:56 PM Thread Starter
Images: 1
It was built in January of 08 its a job 2, I had the radiator replaced once @ 13,000 miles. The radiator started leaking again @ 32,000 I diddnt take it in because I had just put the delete pipe on the week before. I drove it adding water as needed until 46,000 then it started getting worse one day getting on the freeway it blew a bunch of white smoke out the tail pipe and was running really funny. I put the dpf back on when I got home drove to work the next morning and was going to have the mechanic do an oil change before I took it in. I pulled the dip stick and the oil was milky so it went straight to ford. Because it got air in the coolant system it caused the water pump to cavitate and eat through the cover and got water in the oil.
post #9 of 18 (permalink) Old 03-12-2009, 10:55 PM
surveyor13's Avatar
Well I just noticed I have a leak down the back side of my radiator on the drivers side. I guess it is going in. Venturi T is installed. I guess the only silver lining is it happened 2 weeks before I leave for Oregon.
post #10 of 18 (permalink) Old 03-12-2009, 11:23 PM
Ford 6.4 it's just cooler
trapit's Avatar
Just looked at my reservoir and it was 1/2 inch from the cap? I huess this is the reason for the new bottle design
Paul Alewine
2008 F-250 King Ranch AFE Stage II MBRP Duals and Spartan 310 Tuned
2" BDS Lift on 35" Toyo M/T's
Singles Club #74
American Club #13
trapit is offline
Windshield Reservoir Robts 2003-2007 6.0L Power Stroke 3 03-18-2008 12:26 AM
reservoir shocks? chvylac General Ford Truck and Excursion 19 06-16-2007 09:42 AM
HPOP Reservoir leak rescueu 1994-2003 7.3L Power Stroke 1 05-04-2007 11:10 AM
pro comp RESERVOIR SHOCKS chvylac General Ford Truck and Excursion 0 03-30-2006 04:57 PM
