Rim and tire questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dwoz2012, this thread has received 5 replies and been viewed 802 times.
post #1 of 6 (permalink) Old 02-28-2009, 09:39 PM Thread Starter
dwoz2012's Avatar
My 08 SD is stock and I do not want to lift it, but I want to fill the wheel well and get bigger wheels and rims. I have 265/70 R 17 pirellis on the stock rims. So what do you all think about the size I can go with out rubbing? Thanks for any info you can give
dwoz2012 is offline
post #2 of 6 (permalink) Old 02-28-2009, 09:57 PM
I Eat Rice
forcefed6.4ford's Avatar
i've got 35' x 12.5' toyo mt's on an 18' rim. about as big as you can go with a stock ride hight
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 6 (permalink) Old 02-28-2009, 11:02 PM Thread Starter
dwoz2012's Avatar
Thanks, I would like to get new rims to go with the new tires. Looking for options with out the use of a lift so we will see what other ideas the guys come up with.
dwoz2012 is offline
post #4 of 6 (permalink) Old 02-28-2009, 11:29 PM
Ultra Member
Matt05's Avatar
You'd need to say what kind of rim your going to look at. Something with stock offset is going to work fine on a 35 inch tall tire, but if you go something that sticks out a ton, you might not be able to fit 35s without a leveling kit. Just need an idea of specs on wheels you want, to better answer your question.
2008 Ford F-350 XLT Regular Cab: 35" Toyo MTs, 2.5 Icon Leveling Kit, Keystone Hood, 4" Magnaflow, 6" tip, dpf/doc delete, S&B Intake, Spartan Tuned, Autometer Gauges
Waiting to install: Icon TEI Spacer, Icon 4-Link, OUO Traction Blocks, 35" Toyo MTs on 20x10 BMF Novakanes, Spearco Intercooler, Polished IC Pipe, EGR Delete, Polished Intake Elbow
Matt05 is offline
The Following User Says Thank You to Matt05 For this addition to TDG:
dwoz2012 (03-01-2009)
post #5 of 6 (permalink) Old 03-01-2009, 11:36 AM Thread Starter
dwoz2012's Avatar
I am open for sugjestions... I might go alittle wider. I will put a set of fender flairs but do not want the tire to go outside of the flair
dwoz2012 is offline
post #6 of 6 (permalink) Old 03-02-2009, 04:42 PM
Powered By Ford
FordRacing200's Avatar
325/60/R20 BFG all terrains will fit, would look damn good on stock 20s too or whatever wheel you choose.
FordRacing200 is offline
Tire Questions shadowgearx 5.9L Cummins 12 Valve (1994-1998.5) 13 03-29-2008 02:03 AM
Tire size questions dweymer General Ford Truck and Excursion 5 07-05-2007 01:50 PM
**** Cepek tire questions Diesel Dog General Parts and Accessories 2 05-23-2006 03:01 AM
2003 f-350 tire/level kit questions! cmkworm General Ford Truck and Excursion 4 04-06-2006 10:47 PM
First tow...tranny questions and chip questions 05TowBoss 2003-2007 6.0L Power Stroke 5 11-07-2005 11:17 PM
