Filters - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dwoz2012, this thread has received 55 replies and been viewed 4526 times.
post #1 of 56 (permalink) Old 03-01-2009, 12:06 PM Thread Starter
dwoz2012's Avatar
Filters
I am close to getting to change my fule filters. The dealer gave my the $300ish price. He said that they have to drain the high pressure fule line and most of the cost is laber. Anyway I was under the impression that the one on the yop of the motor was a drop in. And the one in the water seperator (on frame rail) is simalar to the ones I have changed for years on gas trucks ans cars. So am i wrong and if so any help so i can do this myselfe will be apecated.:
dwoz2012 is offline
post #2 of 56 (permalink) Old 03-01-2009, 12:56 PM
stevestroke08's Avatar
They both are catridge style drop in filters. Crack the lid open on the engine mounted filter and open the drain vavle on the frame rail mounted filter housing and let drain and change filters. Torque filter caps back to specs listed on the caps to avoid cracking them due to over tightning them. You will need a 36mm socket I beleive. Here is a link to a good place to buy the fuel filters. http://www.dieselfiltersonline.com/F...s-Fd-4609.aspx You can use these or the the Racors. When you get done cycle the key to the on position 4 or 5 times for 30 seconds or so each time but do not start to purge the system and you should be good to go.
2008 F250 CCLB Auto 4x4
stevestroke08 is offline
The Following 2 Users Say Thank You to stevestroke08 For this addition to TDG:
bluovldeezl (03-01-2009), dwoz2012 (03-01-2009)
post #3 of 56 (permalink) Old 03-01-2009, 02:40 PM Thread Starter
dwoz2012's Avatar
Thanks for you help Good looken out.
dwoz2012 is offline
post #4 of 56 (permalink) Old 03-01-2009, 03:41 PM
bushpilot's Avatar
+1 for dieselfiltersonline !
-100 for fleetfilter (theyre parts are NOT spec)
Don R.
Truck Audio,
bushpilot is offline
The Following User Says Thank You to bushpilot For this addition to TDG:
post #5 of 56 (permalink) Old 03-01-2009, 07:02 PM
I don't know where your dealer gets 300 bucks. Mine charges 112, unless I am already getting an oil change, then its just parts. If you do want to do it yourself, I agree...go to dieselfiltersonline.com
Greenhorn Diesel is offline
The Following User Says Thank You to Greenhorn Diesel For this addition to TDG:
post #6 of 56 (permalink) Old 03-01-2009, 08:32 PM
pyro2nite's Avatar
You may want to open the top fuel filter first. Sometimes it will siphon from the tank if you do the fuel separater first.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #7 of 56 (permalink) Old 03-01-2009, 08:41 PM
bushpilot's Avatar
theyre BOTH cartridge filters...NO fuel lines have to be drained (your 08
water separator has a valve/switch on it for draining)...
if you spend 30 minutes draining the water-separator and changing
the TWO filters youre DRINKING too much BEER <while working> !
drain the water separator
change both filters (and o-rings)
cycle the key 4 or 6 times w/OUT starting the engine (listen til you hear the pump stop)
and then START the truck <done> !
Don R.
Truck Audio,
post #8 of 56 (permalink) Old 03-01-2009, 08:43 PM
bushpilot's Avatar
the 2008+ water separator is improved (no longer has the "brass plug") for draining,
the procedure is basically the same as shown here ->
http://dan.prxy.org/Truck/Owners_man...HFCM/HFCM.html
Don R.
Truck Audio,
Hollywood (03-01-2009)
post #9 of 56 (permalink) Old 03-02-2009, 02:08 AM
Send a message via AIM to TreverAdamo
my local dealer ask $200 to do it that is why ill be doing mine and not them.
TreverAdamo is offline
The Following User Says Thank You to TreverAdamo For this addition to TDG:
dwoz2012 (03-02-2009)
post #10 of 56 (permalink) Old 03-03-2009, 12:49 AM
my dealer told me it wood cost 365.00 + 1.5 hrs labor = 496 .67 with tax .
so i looked up the part number and match it with wix filters and got their filter for 69.99 did it myself it took about 45 min .
wix part # 33950
SUPERDUTY!.. is offline
Filters jennamax 2003-2007 6.0L Power Stroke 19 06-05-2007 04:17 PM
CAT filters suprstructure Medium and Heavy Duty 2 09-09-2006 01:36 PM
K&N oil filters DBogo General Ford Truck and Excursion 6 09-03-2006 11:54 PM
Dry air filters 4cstr 1994-2003 7.3L Power Stroke 7 09-02-2006 12:18 PM
Oil filters? BAF250 2003-2007 6.0L Power Stroke 1 06-01-2006 06:57 PM
