My EGR block update - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by trapit, this thread has received 33 replies and been viewed 3581 times.
post #1 of 34 (permalink) Old 03-05-2009, 11:43 PM Thread Starter
Ford 6.4 it's just cooler
trapit's Avatar
My EGR block update
Ok me and a buddy of mine decided to try and get this POS EGR blocked off. Got the two bolts undone and realized that I have a small drip going into the exhaust stream definately a EGR not headgasket. So I am going to bypass the EGR's coolant flow tomorrow. Is it just as simple as taking the line going into cooler one and the line on top of cooler two and hooking them together?
Paul Alewine
2008 F-250 King Ranch AFE Stage II MBRP Duals and Spartan 310 Tuned
2" BDS Lift on 35" Toyo M/T's
Singles Club #74
American Club #13
trapit is offline
post #2 of 34 (permalink) Old 03-06-2009, 12:07 AM
I Eat Rice
forcefed6.4ford's Avatar
Hey trapit. Could you post some picks. Is this easily done in the drive way. How much more of a pain in the arse is it to install a delete plate in the horizontal EGR inlet? I would look at mine (cab is off) but im 18hrs away from it working right now.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 34 (permalink) Old 03-06-2009, 12:54 AM
GUTTS's Avatar
Is this the EGR plug that i saw in the new issue of Diesel mag the plug is for 6.0 and 6.4 ?
GUTTS is offline
post #4 of 34 (permalink) Old 03-06-2009, 01:00 AM Thread Starter
trapit's Avatar
In between the EDOC and cooler one, above the exhaust manifold there is an easy spot to get to. By taking the tire off it's easier, but even with it on it isn't bad. I'm simply sliding a 1/4 inch steel plate in between the two flanges, making a mark for the two holes, drilling then bolting it right in between the two. Noticed the drip, so I'm not done and haven't even run the truck yet for feedback
Paul Alewine
Singles Club #74
American Club #13
trapit is offline
post #5 of 34 (permalink) Old 03-06-2009, 01:52 AM
TDG MAFIA MEMBER #85
onebadf150's Avatar
http://www.bleproducts.com/
you have to use internet explorer to view it !
onebadf150 is offline
post #6 of 34 (permalink) Old 03-06-2009, 02:04 AM
ZeroOne's Avatar
Wait, so you undid the connection right at the back of the horizontal egr cooler? And coolant was dripping out? Starting to think my theory might have been on track. If that "leak" allows coolant out (into the exhaust stream), it will also allow exhaust gas / bubbles into your coolant stream, headed for the degas bottle.
And to the post above.... that plug looks like a block off as a replacement for the egr valve itself on the tail end of the egr system, not the egr inlet at the back of the engine. The 2 o-rings are in the same locations as the 2 divisions inside the egr valve port.
ZeroOne is offline
post #7 of 34 (permalink) Old 03-06-2009, 02:11 AM
********* and Mafia #90
Bcarriveau's Avatar
Heres a good view of the coolers and hoses..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following 2 Users Say Thank You to Bcarriveau For this addition to TDG:
SEABEE08FX4 (03-06-2009), seapig (03-08-2009)
post #8 of 34 (permalink) Old 03-06-2009, 02:14 AM
I Eat Rice
Im getting the EGR cooler fixed. THEN i'll install the delete plates. No coolant problems no more.
post #9 of 34 (permalink) Old 03-06-2009, 03:18 AM
I like Pretty Girls!
Hollywood's Avatar
So the Head gasket was fine then? Just the stupid Cooler?
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #10 of 34 (permalink) Old 03-06-2009, 03:20 AM
I Eat Rice
I will know tomorrow for sure. I will update. Kind of wish I wasnt in Rainbow Lake. Too far away to go and get it when it's done. Wifes a little ticked that I have her Jeep bouncing up and down lease roads.
Update... Silver_Stroker 2003-2007 6.0L Power Stroke 13 01-14-2009 04:26 AM
swapping 53 block with a 55 block DHenson 5.9L Cummins (1998.5-2002) 16 03-26-2008 12:59 PM
SCT update 08F-250 2008-2010 6.4L Engine Tuner Forum 11 11-21-2007 10:13 PM
How to update my SCT? Pittsburgh-05HD 2003-2007 6.0 Tuner Forum 2 02-25-2007 05:15 PM
MPG Update I10HaulR 2003-2007 6.0L Power Stroke 1 06-04-2006 08:28 AM
