Out of fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 9 replies and been viewed 5910 times.
post #1 of 10 (permalink) Old 03-14-2009, 03:30 AM Thread Starter
Out of fuel
So my wife ran her 08 f-450 outta fuel. It wont start, I am familiar with diesel as I own a 01 ctd and 83 mercedes diesel. I know how to bleed those etc work on them. But looking at this truck is like french to me I have zero experience with powerstrokes at all. So basically do I try to bleed it and if so how? Or take it to the dealer?
veritas42 is offline
post #2 of 10 (permalink) Old 03-14-2009, 03:37 AM
sledneck57's Avatar
Read the manual and it will tell you what to do. Turn the key on a few times and there is a button on the pass side door jam (I think) that you push to purge the line. Like I said the manual says I know.
By the way did you just say my WIFES F-450!
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Ridin Dirty Club #37
sledneck57 is offline
post #3 of 10 (permalink) Old 03-14-2009, 05:30 AM Thread Starter
Ya im gonna look at the manual, I didnt even think to look at the owners manual
post #4 of 10 (permalink) Old 03-14-2009, 12:23 PM
R.I.P. DAD
SEABEE08FX4's Avatar
Cycle the key about 10-15 times to prime the pump and crank it it should start up after a few secs.
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #5 of 10 (permalink) Old 03-15-2009, 12:27 AM
Send a message via AIM to deere puller Send a message via Yahoo to deere puller
It may take more than 10 - 15 times, A friend ran his out and it took more like 40-50 key cycles, just to let you know. didnt want you to giv eup after #16 and tow it.
53 willlys dodge 2500 frame,24 valve cummins w/ p pump
59 Chevy 36 with duramax/allison (to be done spring 2010
59 Ford 250 (future project, 6.4/torqshift)
88 Jeep wrangler 3.9 cummins twin turbo
08 F350 CC SB FX4 6.4
08 F350 CC LB 4X4 6.4
09 BMW X5 diesel
deere puller is offline
post #6 of 10 (permalink) Old 03-15-2009, 12:37 AM
truckn'
sexytrkr's Avatar
Send a message via AIM to sexytrkr
wife in the 450....
2014 T800W 600hpISX15 18spd yanking a 2003 XL specialized 110HD with the cheater neck.
93 peterbilt 379ex hood. 3046B 18spd (in time out, broken crankshaft)
Lonestar Diesel club #9
sexytrkr is offline
post #7 of 10 (permalink) Old 03-15-2009, 01:05 AM
Button on the passenger side is emergency cut off for the fuel!
timid1 is offline
post #8 of 10 (permalink) Old 03-16-2009, 06:04 PM
Lesson #1. Don't ever run a diesel out of fuel! Lesson #2 Same as #1.
I agree cycle key and count to five on each key on cycle at least 20 times. Try to start and do another 20 or more and try to start again.
2008 F450 6.4 diesel dually loaded.
2x6 bulldog is offline
post #9 of 10 (permalink) Old 03-16-2009, 06:59 PM
There's a schrader valve on the fuel cooler to bleed the air out. You can run a plastic line off it into a pail / cup / whatever and bleed it at that point.
F350DRW1 is offline
post #10 of 10 (permalink) Old 03-18-2009, 05:47 AM
Cycle the key for 20 seconds at a time,this is the length of time the fuel pump is commanded on.Do this for 5-15 times,hopefully the engine will then start.The dealer has a bleed hose that goes in place of the rear bango bolt on the fuel cooler to bleed the air from the high pressure side of the fuel system.
bronco1 is offline
Alt Fuel! Tired of Traffic? HOV lane Bi-fuel F150! - $10000 taztruck Whats Been Sold 0 01-04-2009 04:13 PM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
Fuel leak from fuel filter drain tube Diezel Dawg 1994-2003 7.3L Power Stroke 11 02-02-2007 01:47 PM
