Oil sample results; Not very good?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hollywood, this thread has received 5 replies and been viewed 1097 times.
post #1 of 6 (permalink) Old 03-17-2009, 10:14 PM Thread Starter
I like Pretty Girls!
Hollywood's Avatar
What do you guys think? it says Action required but doesn't say what?
I just wanted to see if there was any coolant in the oil but that part of this sample is fine. The Aluminum scares me though? or is this normal wear on a newer engine?
this is my first sample on this truck
thanks for any input
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #2 of 6 (permalink) Old 03-17-2009, 11:08 PM
Is it the first oil change? If so it may be normal, not an oil expert by any means though...
krc0864 is offline
post #3 of 6 (permalink) Old 03-18-2009, 02:19 AM
pyro2nite's Avatar
got mine back from Blackstone. The Aluminum was normal till about 26000 miles, then I got the same high levels. Got about another month till the next check. Aluminum is bearings. Not much you can do for now.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #4 of 6 (permalink) Old 03-18-2009, 12:47 PM
I Eat Rice
forcefed6.4ford's Avatar
Ive got visible particals. Looks like potters mud. Just a film on the bung. Not chunks on my bung when I got my last oil change. The diesel tech said it is normal. I was told it was just final break in and my oil should start cleaning up. Never sent anything away for analysis. 98,000km on it. I will on the next oil change.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #5 of 6 (permalink) Old 03-18-2009, 03:22 PM
pyro2nite's Avatar
WOW final break in. Looks like that motor got some life in it. There was a thread somewhere here about syn oil and break in. Looks like all the mileage estimates, including myselfs was a little low.
post #6 of 6 (permalink) Old 03-19-2009, 05:22 PM Thread Starter
Hollywood's Avatar
So I guess its nothing to worry about. I have lots of warranty but still I don't want to be pulling the motor at 200,001 kms when it expires.
2008 F-350 Lariat
sample reads-fuel in oil? bootcamp 2003-2007 6.0L Power Stroke 4 03-08-2009 05:39 PM
Oil sample from a 6L customer CrowsSynthetics 2003-2007 6.0L Power Stroke 14 01-07-2009 10:09 PM
Fuel PSI test drive results, good but bad too HotSauce2138 1994-2003 7.3L Power Stroke 5 11-24-2007 09:25 PM
went to the Track last night!! good results. WBV06CTD 5.9L Cummins (1998.5-2002) 23 03-08-2007 05:50 PM
Magnaflow Sample Sale Mark_Craig Supporting Vendors Forum 0 01-25-2006 04:32 PM
