Customer Satisfaction Program 09B08 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by adrianspeeder, this thread has received 19 replies and been viewed 4164 times.
post #1 of 20 (permalink) Old 03-20-2009, 08:05 PM Thread Starter
TDG Mafia Member #25
adrianspeeder's Avatar
I just got a letter from Ford about fuel injector Orings leaking fuel into the crankcase and causin' bad juju. Just checked my level and it's a bit above full. Goin to the dealer next week.
Adrianspeeder
adrianspeeder is offline
post #2 of 20 (permalink) Old 03-20-2009, 08:37 PM
pyro2nite's Avatar
Anyway you can post that with the TB number? Thanks
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
post #3 of 20 (permalink) Old 03-20-2009, 09:41 PM
Adrianspeeder
Have you noticed your oil level a little high prior to this? If so your oil has fuel in it due to regen. Up to 2 quarts is within spec according to Ford. My truck made oil with the regen on and I am not affected by the recall. Just a thought
Greenhorn Diesel is offline
post #4 of 20 (permalink) Old 03-20-2009, 10:05 PM
Geez, two extra quarts of diluted oil is within Ford spec, two minutes for the hubs to engage is within Ford spec, metal chunks on drain plugs for the engine and differential are nothing to worry about, it makes a guy wonder if they are just "rolling the dice".
Mr.Tourettes is offline
post #5 of 20 (permalink) Old 03-20-2009, 11:23 PM
I think so too. Too much money to fix everything right. I will just keep taking oil samples and get them tested. My dpf is off, so I will see how much dilution I get now. If the engine blows, I will have info to back up against their "in spec" approach. I have had 1 quart of fuel in my truck, the last one was half of that. The next one should be less than 1%
post #6 of 20 (permalink) Old 03-21-2009, 02:18 AM Thread Starter
No TB number, just Program Number 09B08. The dealer wasn't even aware of it, but made me an appointment to bring it in next week and take a look. Never had any warranty work on my only other new truck, the '02, so not sure how they handle these jobs. Do I get a rental if it takes longer than a day?
Adrianspeeder
post #7 of 20 (permalink) Old 03-23-2009, 01:26 PM Thread Starter
I just called and I don't get a rental. I'll camp out 'round the dealer then.
Adrianspeeder
post #8 of 20 (permalink) Old 03-23-2009, 06:20 PM
ZeroOne's Avatar
ZeroOne is offline
post #9 of 20 (permalink) Old 03-23-2009, 09:17 PM
Originally Posted by Greenhorn Diesel View Post
I think so too. Too much money to fix everything right. I will just keep taking oil samples and get them tested......
Where do you take your oil for testing?
kimminau2 is offline
post #10 of 20 (permalink) Old 03-23-2009, 10:54 PM
Blackstone Labs The best 22.50 you will ever spend
Oil sample from a 6L customer CrowsSynthetics 2003-2007 6.0L Power Stroke 14 01-07-2009 10:09 PM
Another VERY satisfied customer TooLoudTooBad 1994-2003 7.3L Chips & Tuners Forum 2 03-14-2008 05:41 AM
Customer Satisfaction & Customer Appreciation MOMBENZ Supporting Vendors Forum 0 09-15-2007 04:35 PM
new DP customer on his way HotSauce2138 1994-2003 7.3L Power Stroke 0 05-17-2007 01:38 PM
the best ever customer service smokinrod Supporting Vendors Forum 3 05-01-2006 06:56 PM
