Should I deinstall? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2cobras, this thread has received 13 replies and been viewed 1168 times.
post #1 of 14 (permalink) Old 03-21-2009, 12:28 AM Thread Starter
Should I deinstall?
I just got done putting the full Spartan package on my truck and low and behold a recall letter comes in the mail for injectors
Question is= Should I remove the stuff I just installed? CA, exhaust before I take it in?
Thanks Jeff
2cobras is offline
post #2 of 14 (permalink) Old 03-21-2009, 12:33 AM
GUTTS's Avatar
I would
GUTTS is offline
post #3 of 14 (permalink) Old 03-21-2009, 12:36 AM
Just hope that your dealer's computer doesn't flag the Spartan. I have no experience in this but a good friend of mine who happens to be a Ford dealer General Mgr. told me that any alteration to the Ford computer is easily detected in two different ways even after your truck's computer has been "put back to OE condition". You may seek out a sympathetic dealer before taking the truck anywhere. Maybe someone can answer why the aftermarket programmer manufacturers aren't up front about warranty problems. Good luck.
volwing is offline
post #4 of 14 (permalink) Old 03-21-2009, 12:59 AM
96Bronco's Avatar
There are really 2 ways to looking at it...
1. If you are worried about them hooking up diagnostics to your truck, then you can put the dpf back on, reprogram back to stock & drive around until you regen once and then take it in. Although for a recall you really shouldn't have to wait for a regen to bring it in, but I would for warranty work.
But...
2. It's not warranty work, it's a recall, the injectors are bad and could not have been caused by the tuner. For a recall they shouldn't have to hook up the diagnostics, they should just replace the injectors no questions asked. So... some might say since it's a recall, regardless of what has been done to the truck, they are obligated to fix it. It is a fault from the factory, so they should just fix it regardless if it is tuned or not , no questions asked.
So why worry about it? The dealer may make a "note" of you removing the dpf and keep it on record for future problems that might be caused by the tuner. With that said, I would be safe and go with option #1.
96Bronco is offline
post #5 of 14 (permalink) Old 03-21-2009, 01:39 AM
To the best of my knowledge, Spartan has been undetectable by Ford. It throws a p1000 code which is the same as the battery being disconnected. I too, if able, I would drive around and let it regen so it looks good. But like I said, as far as I know, Spartan has not been detected as long as the truck is back to stock
Greenhorn Diesel is offline
post #6 of 14 (permalink) Old 03-21-2009, 02:06 AM
Ford 6.4 it's just cooler
trapit's Avatar
it's a recall and they aren't gonna be looking to screw you, they'll just try to get you in then out ASAP
Paul Alewine
2008 F-250 King Ranch AFE Stage II MBRP Duals and Spartan 310 Tuned
2" BDS Lift on 35" Toyo M/T's
Singles Club #74
American Club #13
trapit is offline
post #7 of 14 (permalink) Old 03-21-2009, 02:56 AM
Just Cowboy Up and Do It!
BigRedDually's Avatar
Not speaking for Spartan, but...
I believe Spartan recommends returning your truck to a completely stock condition before having any work done at the dealership.
'08 F350 CC Lariat DRW
Ordered 12/15/06 Built 02/13/07 Delivered 02/28/07
6.4 L PSD, Auto, Tow Boss, Off-Road
Ranchhand Grill Guard, Headache Rack, Brown's Running Boards
Transferflow 98gal Bed Tank
B&W Turnover Ball, FMJ Spray-in Bedliner
F-450 Front Fender Flares
Airaid CAI
Spartan Tuned 275HP
Red
Dually Club #83
Originally Posted by [email protected] View Post
Any part that you make that is expressly designed to remove a functioning emission component is illegal.
BigRedDually is offline
post #8 of 14 (permalink) Old 03-21-2009, 12:50 PM
git-r-done
TSGS69400's Avatar
what is the production date of your truck? I am curious
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #9 of 14 (permalink) Old 03-21-2009, 01:35 PM
I am pretty sure the Job 1 trucks are not part of this. For once, first production doesn't have all the problems: Call your dealer and ask them to run your VIN. If they are a good dealer, they will do it with you on the phone
post #10 of 14 (permalink) Old 03-21-2009, 03:47 PM
pyro2nite's Avatar
Customer Satisfaction 09b08-Injectors is for job 3 trucks
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
