Howling noise under certain rpm's? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by honda_guy4, this thread has received 56 replies and been viewed 25138 times.
post #1 of 57 (permalink) Old 03-24-2009, 12:19 AM Thread Starter
I get a "air howling" noise from under the hood when under light throttle (typically when rpm's are between 1, 600-1,800), and has been doing it for a while. Seems to be more noticeable when temps are colder outside. Anyone else had this or have any idea what could be causing it? It sounds turbo/air intake related to me, but i could be completely off.
I guess i need to take it in and get it fixed so i can get the sct or spartan package! I just hate going to the stealership.
2008 F-350, 6.4L, crew cab, long box, dark shadow gray, Job 2, w/all options except navi or backup camera. Lot's of exterior mods, 4" turbo back stainless steel flo pro exhaust & spartan tuned.
honda_guy4 is offline
post #2 of 57 (permalink) Old 03-24-2009, 12:30 AM
Are you towing when it happens? If so it is the fan clutch kicking in. Sounds like a jet. If you are not towing and if that fan is kicking in, check your coolant. You may have one of the bad radiators. If it is none of that....maybe the belt or idler pulley? Hope it helps
Greenhorn Diesel is offline
post #3 of 57 (permalink) Old 03-24-2009, 12:50 AM
mine does it as well when its cold, But goes away as soon as everything is warmed up so i havent worried about it.
budtoh3zo is offline
post #4 of 57 (permalink) Old 03-24-2009, 01:11 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Are you POSITIVE it's under the hood?...because a bad gearlash set-up in your diff makes the same sound.....if it's not that,...you might have a cracked up-pipe
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #5 of 57 (permalink) Old 03-24-2009, 01:57 AM Thread Starter
Nope, not towing, i know what the fan sounds like, completely different. This sounds like the wind howling/whistling by your house at night when it's really blowing. Coolant level seems to fluctuate, but have never had to add/been low
post #6 of 57 (permalink) Old 03-24-2009, 01:57 AM Thread Starter
Interesting, mine mostly does it when cold and typically goes away once warm as well!
post #7 of 57 (permalink) Old 03-24-2009, 01:58 AM Thread Starter
Positive that it's coming from the front of the truck! Cracked pipe could explain it.
post #8 of 57 (permalink) Old 03-24-2009, 02:57 AM
Rene G's Avatar
mine does it as well, sounds like when my 6.0l's turbo started to go, but I don't think thats the problem, mines been doing that since brand new
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #9 of 57 (permalink) Old 03-24-2009, 03:00 AM Thread Starter
It can be very annoying when cold out, especially around town, does yours typically go away once warm as well?? Thanks!
post #10 of 57 (permalink) Old 03-25-2009, 02:49 AM
yeah it does get annoying cold when cold, normally takes quite afew miles to quit. I dont think mines a cracked pipe bc it takes driving to go away for me, and as soon as i stop it quits.
howling noise powerstrokin8 1994-2003 7.3L Power Stroke 0 03-12-2008 05:52 AM
dt466 rattling noise at 2200 rpm's Bus Man Medium and Heavy Duty 6 04-12-2007 02:52 PM
How many rpm's? 2006f250bob 2003-2007 6.0L Power Stroke 3 11-15-2006 08:16 PM
transmission howling 2006f250bob 2003-2007 6.0L Power Stroke 3 11-04-2006 08:09 PM
RPM's PSmokinD 1994-2003 7.3L Power Stroke 1 03-06-2006 05:42 PM
