Get your recalls done... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 24 replies and been viewed 3616 times.
post #1 of 25 (permalink) Old 03-28-2009, 02:11 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Here is a radiator out of a truck that came in the other day.. Truck started smoking over the weekend and he continued to drive it until it shut down on him going down the interstate. He completely blew the end out of the radiator and blew the degas bottle cap apart. ALL because he didn't come in for a 2 min. recall but the idiot also continued to drive it while all coolant was pouring out. The WHOLE truck is covered in coolant so it isn't like he didn't notice it. Needless to say the cab is now off and tearing into the engine monday...
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 25 (permalink) Old 03-28-2009, 02:16 AM
Some people have more money than brains it seems
Greenhorn Diesel is offline
post #3 of 25 (permalink) Old 03-28-2009, 03:16 AM
R.I.P. DAD
SEABEE08FX4's Avatar
I hate the clamp on endcaps, they leak on more than just the 6.4. My ex had a infiniti Q45 and it had the same prob and it over heated a few times and after 3 radiator replacements I finaly had enough and tracked down a full metal (brass) replacement. Since then never a over heating prob again. Why do they do this? Some will say its cheaper to make but in the end isnt it costing them more in replacement cost for all of these recalls?
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #4 of 25 (permalink) Old 03-30-2009, 03:11 PM
I hate to say it but i hope he gets the bill for the repair. Severe stupidity should come with a fine. Although, i really wonder if this was more of a pressure issue then not having the T recall done. Makes me wonder since i just checked the bottle on my 1-week old truck and they had left the degas bottle pressure cap loose. Maybe we really need to install lower pressure caps...
rock_doctor is offline
post #5 of 25 (permalink) Old 03-30-2009, 03:56 PM
Images: 1
I agree that the guy should'nt have kept driving it with coolant pouring out, but the venture "T" I dont believe does anything to help with the radiator. Ive gone thru 2 radiators since ive had mine installed.
He probibly has coolant in the oil due to air in the system causing the water pump to cavitate and eat thru the cover into the block. Thats exactly what happened to mine and another work truck because we drove them too long with the radiator's leaking.
Is this the guys first radiator thats leaking? Mines leaking right now but I cant afford to lose my truck right now so hopefuly it will last a couple weeks until i can take it in. If not and something happens ford can fix it again since they cant install a radiator that lasts more than 3,000 miles.
mschwing82 is offline
post #6 of 25 (permalink) Old 03-31-2009, 12:29 AM
git-r-done
TSGS69400's Avatar
My truck is a job I though I have had not a single issue. Should I still take it in for the radiaror recall? I Need the venturi T as well and the window recall.
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #7 of 25 (permalink) Old 03-31-2009, 03:45 PM
Hydro's Avatar
YES, you should. With the Job 1 trucks, it's not a matter of "if" the radiator leaks. It's a matter of "when" they will leak. My radiator started leaking after my Venturi recall. The problem with your truck is that the radiator isn't leaking so they won't change it, although they should. If I were you, make it leak before your warranty runs out and get the venturi installed.
Hydro is offline
post #8 of 25 (permalink) Old 03-31-2009, 04:02 PM
sacu's Avatar
My job 1 just started leaking with 16k on it. Funny I just towed my 5th wheel for the first time a couple of days ago. It's going in tomorrow.
08 Ford F350 TowBoss
Spartan Tuned
sacu is offline
post #9 of 25 (permalink) Old 04-01-2009, 02:01 AM
whats the problems with the windows?
nate850 is offline
post #10 of 25 (permalink) Old 04-02-2009, 04:06 AM
supr87gt's Avatar
Is there someplace I can go to enter my VIN to find out what recalls have been done or are needed to be done?
Excuse my ignorance.
2008 Lariat, CC, SB, 3.73, stock 20's
-High idle mod
1987 Mustang GT
-331 CI A4 block
-95# injectors
-90mm TB
-80mm turbo
-Powerglide
-3.27 gear
-28x10.5 ET Drag
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
supr87gt is offline
Recalls lilpooh General Ford Truck and Excursion 3 01-23-2009 06:27 PM
some recalls that people might not have seen Bcarriveau The Parking Lot 0 11-07-2007 04:45 AM
Recalls AllOut0606 1994-2003 7.3L Power Stroke 6 08-22-2007 04:32 AM
Toyota recalls are ballooning BROKER The Parking Lot 6 07-25-2006 01:08 AM
GM recalls 804,000 pickups, SUVs wideopen General GM Truck Forum 3 09-13-2005 07:15 PM
