DPf and Cat delete - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rosco, this thread has received 34 replies and been viewed 6301 times.
post #1 of 35 (permalink) Old 03-31-2009, 11:05 PM Thread Starter
Rosco's Avatar
DPf and Cat delete
Ok gang who has done the DPF and Cat delete, and how much of a pain in the arse is it going to be? any tips would be helpful. There sure are a lot of sensors on those two pieces. Thanks.
2008 F350 White CC Lariat 6.4L "Spartan Tuned"
Rosco is offline
post #2 of 35 (permalink) Old 03-31-2009, 11:27 PM
BogginF350's Avatar
the dpf and cat is easier to swap in my opinion than the dpf only..
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #3 of 35 (permalink) Old 03-31-2009, 11:41 PM Thread Starter
Rosco's Avatar
Are you saying to take it off in one piece? Didn't think of that.....
Rosco is offline
post #4 of 35 (permalink) Old 03-31-2009, 11:49 PM
Rudy@DPFDeleteKits's Avatar
Yes it is easier to do the DPF/CAT Delete because you can remove everything in one piece and do not have to mess with the bolts going around the DPF into the CAT. Easier and cleaner install, not to mention more benefits with going DPF/CAT Delete.
SCT LIVEWIRE 9625OR, SPARTAN TUNERS, AND DPF DELETE KITS IN STOCK! SAME DAY SHIPPING!
*WE WILL BEAT ANY ADVERTISED PRICE, GIVE US A CALL*
Toll-Free Sales # 1-866-757-6537 or (919) 636-1518
http://stores.shop.ebay.com/Rudys-Pe..._sopZ15QQ_scZ1
The Following User Says Thank You to [email protected] For this addition to TDG:
Rosco (03-31-2009)
post #5 of 35 (permalink) Old 04-01-2009, 02:21 AM
Exhaust
Not to highjack this thread but in looking at the DPF/cat delete I see up in the front where you will break the joint there is a bracket attached to the exhaust, looks like a weight/damper it is round looking or something of that sort, just wondering beacause I have not seen it mentioned here, can someone inlighten me on what this is and do I remove it when I do my DPF/cat delete.
thanks
cbenn is offline
The Following User Says Thank You to cbenn For this addition to TDG:
Rosco (04-02-2009)
post #6 of 35 (permalink) Old 04-01-2009, 03:39 AM
thanks
You got it, everything will be removed when doing the DPF/CAT Delete.
Rosco (04-02-2009)
post #7 of 35 (permalink) Old 04-01-2009, 12:03 PM
Agree 100% - only way to go is one piece.
2008 F450 - Pearl Blue with Tan - 4.30 (Job 3)
Spartan 310hp w/TCM, Airaid Drop In Filter, 5" MBRP w/ 6" Tip, 2" level kit, Firestone Air bags in the rear, Bilstein's all around
2010 Open Range 429bhs 5th
http://good-times.webshots.com/album/565591458baIstp
Black06 is offline
The Following User Says Thank You to Black06 For this addition to TDG:
Rosco (04-02-2009)
post #8 of 35 (permalink) Old 04-01-2009, 12:32 PM
BCJAG72
bcjag72's Avatar
I have the sct dpf delete pipe right now. Can I buy a cat delete to connect to the sct dpf delete pipe and use that or do I need to buy the two together? Is it really easier to do the two together? Those bolts around the dpf are a b---h to do.
bcjag72 is offline
post #9 of 35 (permalink) Old 04-01-2009, 02:02 PM
Rudy or someone, as I mentioned in a post a couple up, the assembly where the down pipe and straight pipe starts what is that assembly and what does it do for the existing system, will it effect the exhaust system once the DPF/CAT is installed.
Just wondering??
Thanks in advance.
CB
cbenn is offline
Rosco (04-02-2009)
post #10 of 35 (permalink) Old 04-01-2009, 02:37 PM
powerstroker67's Avatar
Just wondering??
Thanks in advance.
CB
If you are talking about the black canister with 2 bolts and the steel cable..... it's a counter weight for the HEAVY CAT and DPF. It does nothing but add more weight to the exhaust system and damper vibration for the stock parts. So the answer the question, no effect after install of new CAT/DPF pipe.
SPARTAN SCT + H+S TUNERS IN STOCK,SAME DAY SHIPPING TIL 5PM
NEW 6.4 COOLER ONLY DELETES, 6.7 COOLER DELETES BUILD INHOUSE!!!
ONE PIECE, BEST FITTING, AND USA MADE CAT/DPF 3.5,4 AND 5 CUSTOM APPLICATIONS AVAILABLE
[email protected]
www.streetdieselperformance.com
(860)250-6082 Sean tech questions
www.dpfdeletekits.com
(919)636-1518 Aaron sales
2011 F350 Lariat, CC,SB,SRW H+S MINI,CAT/DPF W/ full 5" Magna, 8" Procomp, American Force 22",37" Dunlop Maxx Tractions
2008 F450 Lariat,4X4,4.88's,Job1,Loaded,Spartan310,TCM,SCT w/ Eric's tunes,Elite studs+EGR delete,Updated Head gskts.,POWERSTROKER67 CAT/DPF pipe,AFE,Suncoast T/C,Spearco
powerstroker67 is offline
The Following User Says Thank You to powerstroker67 For this addition to TDG:
Rosco (04-02-2009)
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
cat-delete or muffler-delete Dual K20s 5.9L Cummins (2003-2007.5) 20 09-06-2007 09:49 PM
03-06 6.0L Cat Delete/Muffler Delete dfuser Supporting Vendors Forum 1 04-08-2007 09:07 PM
EGR delete for 6.0 talleystile Whats Been Sold 3 11-19-2006 09:32 AM
need a muffler delete pipe, and pushy pipe delete ~CrazyDiesel~ 2003-2007 6.0L Power Stroke 13 03-31-2006 11:56 PM
