Regen question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dwoz2012, this thread has received 4 replies and been viewed 972 times.
post #1 of 5 (permalink) Old 04-03-2009, 08:31 PM Thread Starter
dwoz2012's Avatar
Regen question
Ok so I had a recall and took the truck in and had it done. Recall # 08B07 had to do with "drivability concerns" and DPF regens...they reprogramed the PCM (Powertrain Control Module Module), TCM (Transmition Control Module), IC (instrument cluster). So on to the question now, I seems that the truck will go into regen every tank of fuel. I do not think it went into regen that often before this recall. Should I have this checked or is this somthing that has most likly been going on and i did not know it. The truck has about 13,000 miles it if that also helps. Also had 08B06 recall done the Venturi installed on the cooling system. Thanks guys
dwoz2012 is offline
post #2 of 5 (permalink) Old 04-03-2009, 09:28 PM
Jesse4812's Avatar
After I had the recall done I started resetting my second tripmeter whenever the truck went into regen. So far it's been pretty consistent, averaging about 275 miles between regen. You're probably just noticing the regens more since you get the message now. A lot of times if you're traveling the interstates you might not even notice the truck's in regen unless you're watching the turbo boost or get the regen message.
'12 F-450 King Ranch 4x4, '11 Expedition King Ranch
Jesse4812 is offline
The Following User Says Thank You to Jesse4812 For this addition to TDG:
dwoz2012 (04-05-2009)
post #3 of 5 (permalink) Old 04-04-2009, 03:35 AM
pyro2nite's Avatar
The primary reason for the recall was to eliminate the regan at idle. It also added to the job 1 and the job 2 the ability to have the information center to tell you when it went into regen.
2008 FX4 3:73 ZF-6 SC SB Transfer Flow
Singles club member 166 H&S Mini, KEM Tunes, S&B intake
pyro2nite is offline
The Following User Says Thank You to pyro2nite For this addition to TDG:
post #4 of 5 (permalink) Old 04-04-2009, 01:11 PM
BCJAG72
bcjag72's Avatar
The recall also was to make it go into more regens for a shorter period of time. It keeps the dpf cleaner and eliminates to high temperatures for long regens. Sometimes you will notice it regens then a half hour later or next time you drive it it will go into another short regen. That is how the tech explained it to me and that is how my truck has been doing it.
bcjag72 is offline
The Following User Says Thank You to bcjag72 For this addition to TDG:
post #5 of 5 (permalink) Old 04-05-2009, 10:28 PM
Mines been going into regen every tank ever since I bought it, so I don't think its a problem.
Sandbox is offline
The Following User Says Thank You to Sandbox For this addition to TDG:
Job #2 Regen, again thedrakester 2008-2010 6.4L Power Stroke 2 03-02-2008 04:26 PM
newbie with regen question BCMC 6.7L Cummins (2007.5-2011) 13 12-13-2007 10:40 PM
Question about regen jdydiesel 2008-2010 6.4L Power Stroke 21 12-05-2007 08:41 PM
Regen question while ideling ?? onebadf150 2008-2010 6.4L Power Stroke 6 10-16-2007 08:03 PM
Regen Question fullservice 2008-2010 6.4L Power Stroke 8 05-21-2007 03:37 AM
