One legger!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by crosstx, this thread has received 8 replies and been viewed 830 times.
post #1 of 9 (permalink) Old 04-09-2009, 10:26 PM Thread Starter
Texas Member
crosstx's Avatar
One legger!!!
anyone else have a one legged truck when they break them loose?
I need to put another locker in the rear anyone have any suggestions of what they are using?
I had one put in my 6.0 but i cant remember what it was:
2008 F-250 Lariat CC/SB
NUTTY PROFESSOR KEM345, MBRP Duals (no dpf, cat,or muffler),
S&B Intake, RCD CAC, NXD 2 stage system, Bilstein 5100's, Pro-Comp trac bars, Banks intercooler, ARP studs, Suncoast tranny
ELITE: TOW Compound Turbos, EGR Delete, BOV, Wastegate, Nozzles, Ported Fuel Rails, ..
B.O.M.B Squad #29
#7
www.kemperformance.com
crosstx is offline
post #2 of 9 (permalink) Old 04-09-2009, 11:07 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Arb...
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #3 of 9 (permalink) Old 04-10-2009, 03:05 AM
4play's Avatar
are you looking for a locker or limited slip.
-DETRIOT LOCKER stays locked all the time, and it may unlock going around corners
-LOCK-RITE locked all the time, installs into carrier. cheaper and easiest to install
-ARB an air locker that when selected switches between open diff and locker
-DETROIT TRUE-TRAC, gear type limited slip. no clutches to wear out.
-AUBURN limited slip, uses friction cones, or clutches. these will eventually wear out.
im sure there are others but those are the main ones. i personally would suggest against a "true" locker for street or towing. but they would be the best for off-road.
4play is offline
post #4 of 9 (permalink) Old 04-10-2009, 03:09 AM
Powered By Ford
FordRacing200's Avatar
I'd go detroit true-trac, perfect for what you wanna do.
FordRacing200 is offline
post #5 of 9 (permalink) Old 04-10-2009, 03:16 AM
O2ShootTheJ's Avatar
one tire fire huh?
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #6 of 9 (permalink) Old 04-13-2009, 03:11 PM
My truck does the one tire deal once in awhile. It seems as soon as you put on bigger tires, the factory settings are not enough. I am going with a TrueTrac when I get the chance. Both my new truck and my 06 did the same thing with 37"s.
Mr.Tourettes is offline
post #7 of 9 (permalink) Old 04-13-2009, 04:21 PM
when you take that limited slip diff out i would be more than happy to take it of your hands
86 1 tonhauler is offline
post #8 of 9 (permalink) Old 04-14-2009, 12:36 AM Thread Starter
Texas Member
crosstx's Avatar
I will save it for ya
B.O.M.B Squad #29
#7
crosstx is offline
post #9 of 9 (permalink) Old 04-14-2009, 12:41 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
just weld it lol no dont do that.
Military Quote Of The Year
SOOTBANDIT is offline
