By-pass filter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dlguns, this thread has received 32 replies and been viewed 3050 times.
post #1 of 33 (permalink) Old 04-11-2009, 09:16 PM Thread Starter
dlguns's Avatar
By-pass filter
Does anyone know for sure if putting on a FS by-pass filter on will void the engine warranty? I wrote Ford an e-mail but haven't heard anything yet. I will let everyone know when they get back to me.
dlguns is offline
post #2 of 33 (permalink) Old 04-11-2009, 09:34 PM
They can void warranty. Check with your dealer service advisor.
dfuser is offline
post #3 of 33 (permalink) Old 04-11-2009, 11:07 PM
What he said^^^^^^^^^. Its kind of up to the dealer. They shouldn't have a problem with it but some will because it isn't factory.
2005 Silverado 4X4 CC LB LLY
Air Lift Bags, Amsoil, KB IOH Kit, BD Manifold, Fumoto Valve, PCV Reroute, Resonator Plugged, Mag-Hytec Diff Cover & Trans Pan, PPE X STD, 4" SS Magnaflow Kitty Ran Off
MadJack Racing-Amsoil Diesel Specialist
Authorized FilterMag Dealer
Authorized Fumoto Dealer & April Special on Fumoto's Free shipping with entire kit.
Dirtbikindad393 is offline
post #4 of 33 (permalink) Old 04-12-2009, 01:31 AM
Ultra Member
Matt05's Avatar
I've been thinking about getting the Amsoil bypass kit. Anything bad about it, that makes the FS better?
2008 Ford F-350 XLT Regular Cab: 35" Toyo MTs, 2.5 Icon Leveling Kit, Keystone Hood, 4" Magnaflow, 6" tip, dpf/doc delete, S&B Intake, Spartan Tuned, Autometer Gauges
Waiting to install: Icon TEI Spacer, Icon 4-Link, OUO Traction Blocks, 35" Toyo MTs on 20x10 BMF Novakanes, Spearco Intercooler, Polished IC Pipe, EGR Delete, Polished Intake Elbow
Matt05 is offline
post #5 of 33 (permalink) Old 04-12-2009, 04:43 AM
O2ShootTheJ's Avatar
i'm in the dark here, can someone fill me in on exactly what this is and what the benefits are?
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #6 of 33 (permalink) Old 04-12-2009, 02:55 PM
Diesel Addict
DINOONE's Avatar
Its another oil filter it keeps your oil a lot cleaner than the stock filter. It acutally allows you to go longer periods between oil changes. Do a search FS-2500 on the board there are numerous threads about it.
2008 Harley Davidson F250 16" Custom Lift, Modded to Hell and beyond! "CEREAL KILLA"
Truck FOR SALE:
http://cgi.ebay.com/ebaymotors/ws/eB...category=39415
DINOONE is offline
post #7 of 33 (permalink) Old 04-12-2009, 03:13 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I would like to answer two questions.
As far as the warranty if you are using a Amsoil filter and if Amsoil knows of a dealer doing this they will contact that dealer because it is against the law. But really why would a dealer stop you from filtering the oil better than they are doing it, it is to there advantage IMO.
This is quote from a other post.
I have had both.
I did not think the FS filter was filtering the oil as well as they claimed. We went round and round about this. The replacement filters are expensive and only are good for only 10k the unit is made very well very good engineering. When I was using Amsoils OEM filters the filter was ok when I stopped the oil did get much darker, I change to Amsoil the oil has been much cleaner since. A note the soot we put in the oil is a lot and is hard to remove. I went 38k on the last oil change the oil was very sooty more than I could stand. The sample at 29k was good for 10k more when I pulled the sample I decided to change the oil I do wish I had done a sample I save the oil for a sample just did not send it in.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #8 of 33 (permalink) Old 04-12-2009, 03:20 PM
Post
Here are By-Pass Filtration Benefits
  • Dramatically Extended Drain Intervals
  • Improved Oil Cooling
  • Increased Filtration Capacity and Life
  • Increased Fluid System Capacity
  • Efficient Small Particle and Soot Removal
  • Significantly Extended Engine Life
  • Equipment Constantly Runs on Clean Oil
  • Increased Engine Efficiency
  • Remove Particles Less Than One Micro
Go here for more info.
Bill
5" SS Tip
post #9 of 33 (permalink) Old 04-12-2009, 03:58 PM
Post
Amsoil now offers an CJ4 that has more additive so it can go longer oil drain intervals 15k at this point.
I have attached the two that apply. I posted this info here as well.
Bill
5" SS Tip
post #10 of 33 (permalink) Old 04-12-2009, 04:51 PM
TDG MAFIA MEMBER #85
onebadf150's Avatar
I have had both.
Bill
I find that to be a very bias statement coming from an amsoil rep ! I currently own 2 FS-2500's on a 6.0L diesel and 6.4L diesel. I test my samples religously and everything comes back in the normal range. Why do you say fs2500 replacement filters are expensive ??? I think I pay like $20 or $30 for the replacement filters which I find to be inexpense. I don't think that anything Amsoil carry's is cheaply priceed how much does the amsoil filters go for ? I understand you are very proud of the product you sell and that's good but I don't find amsoil to the the end all say all in the automotive aftermarket. I recently stop using amsoil oil filters, fuel filters and oil in 6 vehicles b/c I found there customer service and product to not be what it's claim to be.
onebadf150 is offline
The Following 2 Users Say Thank You to onebadf150 For this addition to TDG:
fine69 (04-18-2009), merlin5577 (04-14-2009)
By-Pass Filter question BombDocDiesel 2003-2007 6.0L Power Stroke 12 03-27-2009 04:23 AM
by pass filter hinkle2121 Supporting Vendors Forum 3 07-23-2007 09:51 AM
By Pass Filter Intallations thepavedude 2003-2007 6.0L Power Stroke 16 02-12-2007 05:34 PM
amsoil by-pass filter intsalled skinz0021 5.9L Cummins (1998.5-2002) 5 05-12-2006 05:12 PM
By-pass oil filter system Carssuck 2003-2007 6.0L Power Stroke 1 02-15-2006 02:25 AM
