EGR Valve Removal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jeffd29, this thread has received 11 replies and been viewed 24571 times.
post #1 of 12 (permalink) Old 04-28-2009, 06:16 PM Thread Starter
EGR Valve Removal
Took the truck for a check engine light to the dealer. Dealer says needs new EGR valve, they cleaned it so I could drive the truck until the part came in. Dropped off the truck before vacation only to come back and find it not fixed yet. They say they got the part, but can't get the tool to replace it from Ford. This is a Ford dealership. They have now been waiting/sitting for near 4 weeks for the removal tool.
Is there a special tool to remove it (2008 6.4L)?
Can you clean it without removing it. (Said they cleaned it during the time they were waiting for the part.
Thanks for any help here.
jeffd29 is offline
post #2 of 12 (permalink) Old 04-28-2009, 06:51 PM
I honestly don't know anything about it's removal. Certain tunes have it disabled but it seems that you are all stock
Seems like the dealer is screwing you around, I'd go somewhere else if possible.
Hopefully someone with more knowledge on the EGR valve will chime in for you
Good luck!
F350 PSD SRW King Ranch
11.8 @ 120mph on 37s
8700 lbs.
Spatel23 is offline
post #3 of 12 (permalink) Old 04-28-2009, 07:14 PM
Diesel Kid
Super08Duty's Avatar
Why would you need a special tool? Did you ask them what that tool was?
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #4 of 12 (permalink) Old 04-28-2009, 07:19 PM Thread Starter
The truck is stock. I did not ask what the tool was either. Probably should. I did an Internet search for it and could not find anything.
jeffd29 is offline
post #5 of 12 (permalink) Old 04-28-2009, 07:20 PM Thread Starter
I'm also stuck with this dealer for now. Next closest is 180 miles away. Truck only goes about 30mph right now.
jeffd29 is offline
post #6 of 12 (permalink) Old 04-28-2009, 07:27 PM
Diesel Kid
hmmm, I would ask them what it is. Im interested what you would have to use.
Colton
post #7 of 12 (permalink) Old 04-28-2009, 07:57 PM
yues there is a special tool for the instal of the new egr valve but if your at a dealer that deals with diesels they should have no problem to get the part
o8fordcompletlystock is offline
post #8 of 12 (permalink) Old 04-28-2009, 08:52 PM Thread Starter
You would think so! They say they they have ordered the part and not got it for over 3 weeks. So the truck sits.
jeffd29 is offline
post #9 of 12 (permalink) Old 04-28-2009, 09:26 PM
DieselKid's Avatar
Send a message via AIM to DieselKid
6.4LKids truck was throwing an EGR valve code and he didnt wanna deal with putting the DPF back on to take it to the dealer so he just bought a new one and had me put the new one in. And I'll admit it was a HUGE pain in the *** putting it in, first I sat there and pried up on it with a screwdriver and it was very slowly coming up. Then I said "F" it and just wacked it with a hammer and broke it into pieces and it came right out. I sure wish I wouldve had the puller tool.
08 Mitsu Evo X - SOLD
2003 F-250 6.0L - SOLD
2000 F-250 7.3L - SOLD
Engineering Co-op at Navistar(International)
DieselKid is offline
post #10 of 12 (permalink) Old 06-05-2009, 06:19 PM
EGR removal
Yes there is a tool for removing the EGR valve. If you are having problem with a code with your EGR like p0404 (range performance) the valve is getting stuck and the computer is getting a bad feedback. This happened to mine. On the EGR valve motor, this is a black cover held on with 3 torques screws. Remove and you'll see the linkage. This is a 12 to 6 o'clock range motor that opens the valve. I used oil and manually operated until it free-up. I just did a NJ to Montana and back trip and found that towing I have an EGR cooler leak. This I believe was the cause of the valve sticking. If having the valve stick open you'll lose all your boost psi. and have no power.
jhess is offline
The Following 3 Users Say Thank You to jhess For this addition to TDG:
4613 (06-06-2009), onebadf150 (06-09-2009), Super08Duty (06-05-2009)
LMM Exhaust Gas Recirculation Valve and Cooler Removal ripmf666 GM Spec Info 0 12-28-2008 10:47 AM
shutoff valve removal?? bigdaddysdaddy 5.9L Cummins (Pre 1994) 1 03-25-2008 06:26 AM
Air shutoff valve and 3 way fuel valve '05Supersmoker Sled Pulling 2 02-04-2008 11:23 PM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-07-2007 11:58 PM
1998 24-valve compared to 12-valve Michael 5.9L Cummins (1998.5-2002) 1 06-28-2006 04:22 PM
