Tranny Flush - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06jimmy, this thread has received 32 replies and been viewed 3662 times.
post #1 of 33 (permalink) Old 04-30-2009, 04:05 PM Thread Starter
Images: 2
Tranny Flush
Does anyone know if there is an acceptible synthetic trans fluid for our automatic tranny's? I want to do a tranny flush and I'm debating going to Ford or not. I know of a tranny shop that will flush with a synthetic fluid if I want but I need to provide the fluid.
06jimmy is offline
post #2 of 33 (permalink) Old 05-01-2009, 12:30 AM
Amsoil, need to be Mercon SP approoved as per specify in you owner manual.
http://www.amsoil.com/storefront/atf.aspx
F-350 SRW 4X4 crew-cab lariat, 6.4 PSD, Banks ram air+ spartan dpf delete pipe, flo-pro 4'' straipipe.Mag-Hytec tranny oil pan.ELITE head stud +new gasket installed$$$$ coolant filter,
F-350 DRW crew cab KING RANCH 2007,6.0 powerstroke,ARP head stud, Bulletproof EGR cooler,coolant filter,SCT x3with innovative tune,
Quantum is offline
post #3 of 33 (permalink) Old 05-01-2009, 12:36 AM
I Eat Rice
forcefed6.4ford's Avatar
All ATF is synthetic.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #4 of 33 (permalink) Old 05-01-2009, 12:53 AM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
Our Amsoil ATF is approved for your truck it is good for 50k or one year.
I have given you a link to the info.
I will send you a PDF on your truck.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #5 of 33 (permalink) Old 05-02-2009, 10:26 AM
KJR0360's Avatar
I would only use Mercon SP from the dealer. I had a trans go on me years back form using the wrong fluid. It's expensive but you don't change it that often. I use Amsoil for my oil, gear, grease, ect, and think it's great. I just wouldnt risk it with the trans. Just my $.02. Ken.
08 F-250 SC Lariat 4x4 6.4l, Spartan tuned, DOC/DPF delete, S & B CAI, Amsoil oil by-pass, coolant filter
R.I.P. 03 F-250 SC XLT 6.0
KJR0360 is offline
post #6 of 33 (permalink) Old 05-02-2009, 01:17 PM
I understand your concerns but Amsoil will work just fine. I know it is not a fair comparison I use it and I am at 70k I have others with way more miles than I do.
It would be considered severe duty and only Guaranteed for 50k in the 6.4.
Bill
5" SS Tip
post #7 of 33 (permalink) Old 05-02-2009, 01:41 PM
bushpilot's Avatar
Bill
but YOU dont own a 5r110 TORQ-SHIFT !
ONLY MERCON SP is approved for use in the 03-CURRENT 6.0L 5r110 TORQSHIFT
MERCON SP is available on the "net" and at some local retailers...i know
the price has floated up a little but its less than 1/2 the price (at a retailer)
than what the dealer will try to get !
Don R.
Truck Audio,
bushpilot is offline
post #8 of 33 (permalink) Old 05-02-2009, 01:52 PM
4cstr's Avatar
Images: 35
No he doesn't.
But...in the link he provided Amsoil does recommend their product for fluid that requires Mercon V and SP.
From there...its up to the original poster to follow what he wishes.
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
CrowsSynthetics (05-02-2009)
post #9 of 33 (permalink) Old 05-02-2009, 03:10 PM
Banned
Ask you local dealer to sell it to you from his 55 gallon drum. I know my local dealer will sell it bulk in my containers for about 1/2 the cost of buying it in quarts.
wastedwagesracing is offline
post #10 of 33 (permalink) Old 05-02-2009, 05:33 PM
Big_Dezel's Avatar
Send a message via Yahoo to Big_Dezel
Sp is synthetic
6" lift 37's DPF/DOC Delete Spartan Tuned
Get 'cha Some!!!
Big_Dezel is offline
$$ to flush tranny.. Cowbizzoy 5.9L Cummins (2003-2007.5) 2 02-05-2008 12:48 AM
tranny flush slowmans 2003-2007 6.0L Power Stroke 1 08-11-2007 03:09 AM
Allison Tranny Flush lovethedmax Duramax 2004.5-2005(LLY) 10 07-28-2006 05:54 PM
Tranny fluid flush Motown Fire 2003-2007 6.0L Power Stroke 4 04-19-2006 01:26 AM
TECH: HOW TO FLUSH YOUR 5R110W Tranny Bear Hunter 2003-2007 6.0L Power Stroke 15 11-07-2005 01:57 PM
