a little help fellas... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brock44, this thread has received 6 replies and been viewed 801 times.
post #1 of 7 (permalink) Old 05-02-2009, 01:55 AM Thread Starter
i have a new 09 250 and want just to do a leveling kit and put 37's on my stock 20's.....whats the best leveling kit out there? ready lift? daystar?
brock44 is offline
post #2 of 7 (permalink) Old 05-02-2009, 05:09 AM
Rene G's Avatar
I would go with Icon
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #3 of 7 (permalink) Old 05-03-2009, 02:52 PM
fine69's Avatar
You may have rubbing issues trying to fit 37's on a 250 with just a leveling kit.
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #4 of 7 (permalink) Old 05-05-2009, 02:11 PM
Auto's are for pansies
Slick Willie's Avatar
I have the 2.5" AutoSpring pucks up front, but I have a F-350, so the rear blocks are bigger. I'd recommend the AutoSpring 2" for you if you just want 35's and to sit level. Otherwise, you'll get an entire kit (with blocks and pucks) which I don't have any recommendations for.
There are a few threads around here about 37's with stock drivetrain, leveling kit, etc. Search around a little and you might find some good advice.
Slick Willie is offline
post #5 of 7 (permalink) Old 05-05-2009, 06:53 PM
Team White
InMotionJosh's Avatar
I think you are going to find most people to vote for the ready lift sst or the icon 2.5 kit. I personally would go with the icon because it comes with the new springs and new shocks. I would hesitate running 37s on just a leveling kit even if the manufacturer says its possible.
I am going to be running a 4.5 on 37s and im worried they will rub too much. I am using aftermarket 10 inch wide wheels though
2011 F350 CCLB DRW Lariat 2wd
AmericanForce/Nitto/Recon/Viair/T-Rex/MBRP/RetroSolutions/SwingCase/AmericanRollCover/WeatherTech/Westin/EzDown/
www.inmotionbuilders.com
InMotionJosh is offline
post #6 of 7 (permalink) Old 05-05-2009, 07:03 PM
Diesel Kid
Super08Duty's Avatar
Ready lift has lots of different leveling kits that work good.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #7 of 7 (permalink) Old 05-05-2009, 07:12 PM
Originally Posted by InMotionJosh View Post
...I would hesitate running 37s on just a leveling kit even if the manufacturer says its possible.
I am going to be running a 4.5 on 37s and im worried they will rub too much. I am using aftermarket 10 inch wide wheels though...
I know this topic has been in other posts, but still. 37's won't rub the body with a leveling kit, just the cardboard inner fender at the rear of the fenderwell. That can be cut with any bladed device (carpet cutter, pocket knife, etc) and doesn't compromise any function (there's nothing behind it) and can be cut to look like it's supposed to be there. With backspacing over 6" +, they'll rub the control arms, but if you have less than 6" +backspacing, they won't rub the control arms. That goes for any size rims, but not over 13.50 tires. If you have wider tires, you need less backspacing to compensate.
Hi fellas need opionion please bpul2113 5.9L Cummins 12 Valve (1994-1998.5) 3 05-02-2009 05:10 AM
Hey fellas have a Question for ya JOHNDEEREGREEN 5.9L Cummins (2003-2007.5) 5 03-15-2008 07:37 PM
Need some help fellas TWMAN Introductions 13 11-01-2006 03:41 AM
For you fellas that have installed guages... imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 16 10-15-2005 07:36 AM
You know fellas, maybe fat chicks aren't so bad partsguy662 The Parking Lot 45 06-13-2005 04:39 AM
