Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordfanatic69, this thread has received 12 replies and been viewed 1027 times.
post #1 of 13 (permalink) Old 05-05-2009, 03:23 AM Thread Starter
Smokin
fordfanatic69's Avatar
Question
I am considering buying an 09 and was wondering if I can still do the high idle mod and the 2 low mod on the 09 6.4?
09 F250 Crew Cab FX4
5% tint 35% whole windshield w/5% brow
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
5" Flow Pro No Muffin W/6" tip
Spartan 310
fordfanatic69 is offline
post #2 of 13 (permalink) Old 05-05-2009, 05:25 AM
High idle yes you can, and if you get the manual hubs you can still do 2 LO
budtoh3zo is offline
post #3 of 13 (permalink) Old 05-05-2009, 10:53 PM Thread Starter
Smokin
Are you saying that it can't be done like on the 06 by cutting a wire and splicing in.
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
Spartan 310
post #4 of 13 (permalink) Old 05-06-2009, 04:04 AM
Oh im not sure never heard of it or done it, maby someone else can chime in. or can you discribe it alittle more?
post #5 of 13 (permalink) Old 05-06-2009, 05:03 PM
Auto's are for pansies
Slick Willie's Avatar
I have 2 low and 2 low low.
. in the Waggy. But it has a three speed tripple sticked tcase.
Slick Willie is offline
post #6 of 13 (permalink) Old 05-07-2009, 12:30 AM Thread Starter
Smokin
You also have a little sausage...........for real can you cut the wire like you can on the 06 and put a switch in the middle
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
Spartan 310
post #7 of 13 (permalink) Old 05-07-2009, 02:35 AM
were did you splice into the 2006 i could have a look to see if you can, I know the hubs are backwards from the older once.
post #8 of 13 (permalink) Old 05-07-2009, 04:28 AM Thread Starter
Smokin
I know on the passenger side fire wall there is a red wire going to the four wheel drive u cut the wire in half and put a switch on it and u can turn it on and off. I will try to get some pics tomorrow .
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
Spartan 310
post #9 of 13 (permalink) Old 05-07-2009, 04:53 AM
SAK
Truck Toyz
SAK's Avatar
The 08+ have a separate vacuum controller for the 4WD, its on top of the fuse box under the hood, so I'm sure you can splice in a switch that sends the signal to the pump to turn on the vacuum.
How do you do the high idle on the 08+????
2011 Sterling Gray Lariat
5.5" ICON/OUO Lift
20x10 BMF S.O.T.A.'s
37x13.50R20 Toyo MT's
OUO 7" Traction Blocks
OUO Track Bar Ball Joint
Amp Steps
Mag-Hytec F&R Diff Covers
Built by: TRUCK TOYZ
SAK is offline
post #10 of 13 (permalink) Old 05-08-2009, 01:35 AM Thread Starter
Smokin
Here is how you do the 2 Low on the 06
ID:	18715   Click image for larger version
ID:	18716   Click image for larger version
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
Spartan 310
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
