Egt sensor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Quantum, this thread has received 1 replies and been viewed 1485 times.
post #1 of 2 (permalink) Old 05-05-2009, 10:20 PM Thread Starter
Egt sensor
i just order my flo-pro 4'' stainless straight pipe, i would like to buy new sensor(3) because dpf-cat delete. i already remove the dpf densor when i did installed my dpf delete pipe but it is a %/%%&P(*&$/$"/". what is the part number so i can order it directly from newfordparts.com. by the way,i have a dpf delete pipe if somebody is interested in it,PM me with an offer and it'll be yours. Thank!
F-350 SRW 4X4 crew-cab lariat, 6.4 PSD, Banks ram air+ spartan dpf delete pipe, flo-pro 4'' straipipe.Mag-Hytec tranny oil pan.ELITE head stud +new gasket installed$$$$ coolant filter,
F-350 DRW crew cab KING RANCH 2007,6.0 powerstroke,ARP head stud, Bulletproof EGR cooler,coolant filter,SCT x3with innovative tune,
Quantum is offline
post #2 of 2 (permalink) Old 05-06-2009, 10:22 AM
This was posted on another forum. I bought mine for something like 73.00 from Ford:
EGT Probe 8C3Z-12B591-D
There are three EGT probes. One thing to consider before buying the EGT probes is the production date of your truck. From what I have been told by my Ford parts guy and some other people on this forum is that the early production job#1 trucks had a different part number for the EGT probe. The later production job#1, job#2, job#3 trucks use the part number listed above. If you have any question on which one you may have, give your VIN number to the Ford parts guy you use and he should be able to determine which one you need.
Craig02711 is offline
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 01:54 AM
cam sensor johniedino 1994-2003 7.3L Power Stroke 2 03-22-2008 11:27 AM
Cam Sensor? TurboTPI 1994-2003 7.3L Power Stroke 9 12-18-2007 02:19 PM
ICP sensor??? 03ford 2003-2007 6.0L Power Stroke 16 10-21-2007 02:02 AM
7.3L Map Sensor 4cstr Whats Been Sold 0 08-25-2006 03:16 AM
