nitrous - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Quantum, this thread has received 47 replies and been viewed 3219 times.
post #1 of 48 (permalink) Old 05-09-2009, 12:14 PM Thread Starter
nitrous
I have the 275 spartan and planning to order a nitrous kit ) do i need a special tune to run with nitrous. Righ now with 275 + CAI i'm doing 8.61 1/8 miles, i should have my flo-pro 4'' straight installed this coming week. with nitrous do you think i'll do les that 8.4 1/8 miles. What is pros and cons of nitrous for drag racing?? i was looking at nitrous express or Zex or any other you recommend?? is it better with a switch manualy control or a full trottle switch that automaticaly turn on when full trottle. any help would be appreciate. Thank.
F-350 SRW 4X4 crew-cab lariat, 6.4 PSD, Banks ram air+ spartan dpf delete pipe, flo-pro 4'' straipipe.Mag-Hytec tranny oil pan.ELITE head stud +new gasket installed$$$$ coolant filter,
F-350 DRW crew cab KING RANCH 2007,6.0 powerstroke,ARP head stud, Bulletproof EGR cooler,coolant filter,SCT x3with innovative tune,
Quantum is offline
post #2 of 48 (permalink) Old 05-09-2009, 01:34 PM Thread Starter
should have told you that i don't know much about nitrous so any thing important to know you should tell.
Thank
Quantum is offline
post #3 of 48 (permalink) Old 05-09-2009, 01:46 PM
I Eat Rice
forcefed6.4ford's Avatar
1) You dont need a special tune to run nitrous.
2)our 60' times will improve. How much? Depends on the jet size and your abilities.
3)Pros of N2O. Increase in power(obvious), cools the intake charge for more air, lowers EGT's, Supplies oxygen for a cleaner burn, Doesnt increase cylinder pressure as much as water meth or propane. Con's 1) Too much N2O is baaaaad, The bottle is always empty, depending on where you live. Getting refills might be a PITA.
4)I would have a throttle control switch. The bottle should last longer unless you are beating on it all the time. Vary rarely am I WOT driving normally. The "Go Baby Go" button is cute. But I would feel stupid if I forgot to press it during a race. Throttle switch is just simpler once you arm the system.
Hope this helps.
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
The Following User Says Thank You to forcefed6.4ford For this addition to TDG:
whitestroker (05-13-2009)
post #4 of 48 (permalink) Old 05-09-2009, 01:49 PM
sledneck57's Avatar
Nothing imo is a con to drag racing with nitrous. Either of those kits are the best way to go I think. I've got the zex kit with a .88 jet controlled on the throttle position sensor. Works great. No different tuning is required.
08 F-350 CC SB 4X4
Zex Nitrous
Spartan Phalanx
AFE stg 2
Flo-Pro 5"
Lift\Rims\Tires
Canadian Club #0
Ridin Dirty Club #37
sledneck57 is offline
post #5 of 48 (permalink) Old 05-10-2009, 09:46 AM Thread Starter
Thank for reply guys, i do hesitate between zex 82028 that only got throttle switch. and zex 82079 that got the same throttle switch + boost activate switch. witch one should i get???where do you connect the tps switch?wire color??? Thank again.
Quantum is offline
post #6 of 48 (permalink) Old 05-10-2009, 03:24 PM
I Eat Rice
I would go with the throttle possition sensor only. You'll be burning up your bottle on the highway when merging/passing. I can get 45-47psi rolling on to get up to speed.
post #7 of 48 (permalink) Old 05-10-2009, 05:56 PM Thread Starter
are you using nitrous for daily driving??? must cost you a lot$$$$ in my case i just want it for drag race against gm and Dodge .(i'm already faster but would like a little bit more) ) If i use only TPS, that mean that when i'm doing a boost launch, as soon as i floor it ,nitrous will start boosting power??? is it ok ?? Thank again
Quantum is offline
post #8 of 48 (permalink) Old 05-10-2009, 05:57 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
I have a used nitrous kit for sale...
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #9 of 48 (permalink) Old 05-10-2009, 06:15 PM Thread Starter
how much are you asking for??? what's include with the kit??? brand??? model number??? why are you selling???
Thank!
Quantum is offline
post #10 of 48 (permalink) Old 05-10-2009, 06:20 PM
TANK'S 250's Avatar
Images: 38
I got it for a great deal,....I paid $464 shipped to my door,...never installed it,...come up with a fair price,...and it's yours....
I don't know much about nitrous,..hopefull ythese pics will help to answer your questions.
(2) 10lb bottles
(2) bottle warmers
(2) solenoids
(1) purge solenoid
switches of some sort
and some other stuff....
switches and other stuff not in pics,....they were camera shy....
Special thanks to:
KLMperformance.com
Black Ops Bumpers
50 \nitrous/ 75 cumminsmega 5.9L Cummins (2003-2007.5) 4 04-30-2008 02:32 AM
Nitrous Q's R4farms Dodge Performance Forum 5 03-22-2007 05:37 PM
nitrous kit stroke250 2003-2007 6.0L Power Stroke 5 06-02-2006 12:48 AM
Nitrous is in DODGEDIESEL2500 5.9L Cummins 12 Valve (1994-1998.5) 5 05-18-2006 12:32 AM
Nitrous is in... 05 2500HD GM Performance Forum 5 08-27-2005 04:58 PM
