Diesel Truck Forum - TheDieselGarage.com - View Single Post - Big cam snap test
View Single Post
post #2 of (permalink) Old 01-17-2017, 02:26 AM
tenwheeler
Radiator pressure tester. Replace the hose assembly with a pushloc one and a #4 male JIC on the end. Connect that to the end of the steel line that screws on to the after cooler. Pump it up to 20 PSI and run the engine to full throttle quickly. Snap pressure is maximum before the governor cuts it back.
tenwheeler is offline
