Diesel Truck Forum - TheDieselGarage.com - View Single Post - Cat 3406 B/C Injection pump combination
View Single Post
post #3 of (permalink) Old 01-17-2017, 05:50 AM
Cat Attack
Cat Attack's Avatar
Use the 10 peec pump cam. If the 2ek has a 5888 pump its also a C pump. Probable has 3422's or 23's where its a 2EK but also may have 3587's or 88's. Gotta find that out first. The 8Pn pump cam and engine cam both suck and are for 16:1 or 16.25:1 compression and 8289 or 8290 nozzles which suck as well. The complete advance off the 8pn will work fine on the 2EK and since the bonnets are all leaking it would be the time to pull all barrels and plungers and change the rack and install the one from the 8pn along with governor and all associated parts. Also get the purple stripe gov spring from the 4mg or 5kj.
Larry
Cat Attack is offline
The Following 2 Users Say Thank You to Cat Attack For this addition to TDG:
Jasong (01-21-2017), Oxbow12 (01-18-2017)
