When using the pills, always put the pills into your tank then fill your tank with fuel, so they will spread throughout your tank quicker. This insures that your pills went down into the tank. For your first 2 tanks of using the pills, it is very important to give your tank a "BoosterShot" to boost your system.... Use 2 pills if your tank holds 1 – 8 gallons, 4 pills for 9 – 16 gallons, 6 pills for 17 – 24 gallons, 8 pills for 25 – 32 gallons, 10 pills for 33 – 40 gallons, 12 pills for 41 – 48 gallons or 14 pills for 49 – 56 gallons. (If you have already started using the pills, it is still recommended to give your next 2 tanks a "BoosterShot.")
After your "BoosterShot", then use the normal dosage of 1 pill for every 8 gallons, which is 1 pill for 1 – 8 gallons, 2 pills for 9 – 16 gallons, 3 pills for 17 – 24 gallons, 4 pills for 25 – 32 gallons, 5 pills for 33 – 40 gallons, 6 pills for 41 – 48 gallons or 7 pills for 49 – 56 gallons. Remember… it’s best to always drop the pills into your tank first and then put the fuel in. This insures that your pills went down into the tank. Always use 1, 2, 3, 4, 5, 6 or 7 pills every time you put any amount of fuel into your tank according to the size of your tank as prescribed above. Don't ever short-change your tank on the recommended dosages!
