240d ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerSMOKE_08, this thread has received 2 replies and been viewed 2112 times.
post #1 of 3 (permalink) Old 07-11-2010, 08:41 PM Thread Starter
powerSMOKE_08's Avatar
240d ?
hi i have a 240 d four cylinder engine and im not real sure what these motors are capible of also any info on how to turn up the fuel pumps or how to attach a turbo would be nice thx
jeremy
powerSMOKE_08 is offline
post #2 of 3 (permalink) Old 08-14-2010, 05:34 PM
I'm not sure there is much you can do with the MB 4-cylinder to help it out power-wise. The best thing I can think of is to transplant a 5-cyl. turbo engine (readily available) into it.
For more info, try this site: http://www.peachparts.com/shopforum/...splay.php?f=15
The folks there can answer most any question about Mercedes diesels.
DagObx is offline
post #3 of 3 (permalink) Old 09-16-2010, 09:09 AM
Syöttöruuvi=fuel screw. Open it to get more fuel.
Maksimikierrokset=Max rpm. Turn in to get more rpm. They can take easily 6500-7000rpm.
Tyhjäkäynnin säätö=Idle rpm. Open to lower, turn in to raise rpm. When you turn out the fuel screw the idle rpm usually raises so you need to lower it from this screw.
Top screw is idle fine tuning, you don't need to touch it.
http://www.nic.fi/~danes/w638_2/jutut/pic/p0091.jpg
You can also advance the timing a couple of degrees to get a few more HP and less smoke, especially at higher rpm.
Open these 3 bolts and 1 on the other end of the pump to adjust timing.
http://www.nic.fi/~danes/w638_2/jutut/pic/p0313.jpg
xxxxxV8Lenny is offline
