Having a pump turned up 10% input/opinions ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Brad, this thread has received 2 replies and been viewed 1647 times.
post #1 of 3 (permalink) Old 08-13-2011, 03:26 PM Thread Starter
Diesel Brad's Avatar
Question Having a pump turned up 10% input/opinions ?
I have an oddball car Ive been commuting to work in; 81 Peugeot 505 Turbodiesel. I prefer my Ford diesel, but fuel prices suck ($3.75 gal where I'm at) and this car does get 37 mpg.
Long story I took the old engine out to repair a bad oil leak.
Found a rebuilt engine for cheap so, it's a no brainer that I grabbed it & I'm throwing it in. But........
Problem is at 80 horsepower it has no balls even with a turbo.
Does anyone think if I have the pump turned up 10 % it will make a noticeable improvement ? Should I get a pyrometer & watch the EGT ?
Thinking about a K & N filter while I'm at it: opinions ?
You know you live in a Country run by idiots if....
Hard work and success are rewarded with higher taxes
and government intrusion, while slothful, lazy behavior
is rewarded with EBT cards, WIC checks, Medicaid and
subsidized housing, and free cell phones.
2011 Ford F150 Ecoboost
1970 International Loadstar DV550
Diesel Brad is offline
post #2 of 3 (permalink) Old 08-13-2011, 03:50 PM
Old Fart
dbennett48's Avatar
You MUST get a pyro, or you will burn up a couple of pistons. This is true in ANY turbo-diesel engine.
Dave
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 3 (permalink) Old 09-09-2011, 06:01 PM
Originally Posted by Diesel Brad View Post
IProblem is at 80 horsepower it has no balls even with a turbo.
Don't need a pyro in passenger car. If it's the Lucas rotary pump then there's a problem with timing when turning it up. It's like Cummins PT system, it advances timing when you turn more fuel to it. So, when you give a lot of fuel to it, at some point you must retard the timing and that makes fuel economy worse. But it's a very strong engine and takes a lot of abuse.
xxxxxV8Lenny is offline
Opinions on the FASS fuel pump itali83 Medium and Heavy Duty 9 01-03-2011 03:14 AM
turned pump up..no smoke jrod1986 7.3L and 6.9 IDI (Pre 1994) 0 08-06-2010 03:37 PM
turned up Injection pump fordfreak 7.3L and 6.9 IDI (Pre 1994) 36 07-14-2009 03:25 AM
Brake pads going out. need opinions/input Darsey715 General Ford Truck and Excursion 13 04-27-2008 04:22 AM
This turned is turned up!!! Truck pics WBV06CTD 5.9L Cummins (1998.5-2002) 18 07-03-2007 08:21 PM
