Fuel/water separator - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jayro, this thread has received 2 replies and been viewed 856 times.
post #1 of 3 (permalink) Old 05-01-2014, 10:31 AM Thread Starter
I had some work done on a piece of equipment with a Deutz BF4M1012. It was bogging down when a load was put on it at high RPM's. One of the things they did was to replace the filter head for the fuel/water separator. They replaced it with just a fuel filter, no separator. Is this an issue, or does it not matter? They also said it might need a check valve. As it was hard starting after trucking it home, I suspect this to be true.
Thanks
Jayro is offline
post #2 of 3 (permalink) Old 05-02-2014, 03:05 AM
I would tell them that it is unacceptable and you want the right one. Filtration is very important, trying to get the right kind of filters, and a check valve that works properly is not as easy as it sounds. On some parts, OEM is by far the best.
Just a thought!
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
Jayro (05-02-2014)
post #3 of 3 (permalink) Old 05-09-2014, 08:06 AM Thread Starter
I've been having on going trouble with this thing. One of the things they ask me whenever
I call the shop who worked on it, is if I tried running it out of a jug of fuel. What's the purpose of this? I see no evidence of fuel contamination from the tank.
Jayro is offline
draining fuel water separator problem PKeel 08 6.4l 2008-2010 6.4L Power Stroke 5 10-13-2011 03:39 AM
fuel water separator drain plug jethrow Whats Been Sold 6 03-11-2009 01:06 AM
Question regarding water/fuel separator stumppuller08 2008-2010 6.4L Power Stroke 1 02-11-2008 03:43 PM
Fuel water separator heater test [email protected] 2003-2007 6.0L Power Stroke 2 12-19-2007 12:48 PM
Water in fuel separator? Bcarriveau 2003-2007 6.0L Power Stroke 2 09-25-2007 05:49 PM
