vw tdi mods - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blkd. out 03, this thread has received 6 replies and been viewed 1650 times.
post #1 of 7 (permalink) Old 08-06-2006, 05:38 PM Thread Starter
vw tdi mods
a friend of mine got a 04 tdi vw.What chips or tuners are available for this car?What are some other reliable mods,he doesent want a race car.
blkd. out 03 is offline
post #2 of 7 (permalink) Old 08-06-2006, 07:40 PM
There are several companies making chip, namely Rocketchip. Kerma TDI sells several upgrades including nozzles, and turbos for some models. There's also DieselPower that sells the Digi-PD box that plugs in between the injectors and ecu which can be easily removed with no footprint so there's no problems with the warranty. DieselPower is also testing something for the turbo, but I haven't read the specifics on what it is supposed to do.
your2slow is offline
post #3 of 7 (permalink) Old 08-07-2006, 02:13 AM
Andy has his passat tuned pretty well...maybe he will chime in to help you
Liftedpsd is offline
post #4 of 7 (permalink) Old 08-08-2006, 12:08 PM
I have been using a VanAaken chip. I opted not to have my chip tuned, since you have to send it back to the tuner to go back to stock. They do not make un uploader for the vw right now.
NMU98 is offline
post #5 of 7 (permalink) Old 08-08-2006, 04:19 PM
DPDIESEL's Avatar
Go with a van Aaken chip. They give a good power gain, plug in under the hood and can be easily removed if needed. They are also not that expensive. Here is a link for you to look at: http://dominatordiesel.com/catalog/i...hp?cPath=73_76
Performance Diesel Motorsports
5,500 RPM Common Rail Anyone??
DPDIESEL is offline
post #6 of 7 (permalink) Old 08-09-2006, 05:10 AM
I've been reading about a flash programmer from Revo Technik called SPS, but I can't find a whole lot of info on it. I'm not sure if you have to send the ecu to them first then be able to switch programs or if just plugging in the programmer works with no other modifications.
DPDiesel,
I was looking on your website and it doesn't look like any of those Van Aaken boxes will fit my 06 1.9 TDI unless I'm missing something. Do you have a tuner box for the 06 1.9 TDI's?
post #7 of 7 (permalink) Old 08-09-2006, 03:43 PM
DPDIESEL's Avatar
Yes,
The SBX-100R will fit most 2006 1.9L TDi's. The later ones use the SBX-105R. If you want some more info PM me your email address and I can send you some.
DPDIESEL is offline
